A sublayer can turn the Path Tracing denoiser off without the Render Settings panel showing it. The panel shows the denoiser on, but the viewport output is clearly not denoised. Adding a stronger layer that explicitly sets omni:rtx:pt:denoising:enabled = 1 does re-enable denoising, but the results are different from a stage where no layer authors the denoiser at all.
I’ve included a sample file, steps to reproduce.
- open
newStart.usd, enable path tracing, and verify Denoising is checked - insert
testOff.usdas a sublayer - check the denoising flag in the render settings & verify with viewport
- insert
testOn.usdas a sublayer abovetestOffand verify with viewport.
I realize one solution here is “don’t leave render settings saved in sublayers,” but Kit saves render-settings changes to the current authoring layer by default. That makes it very easy to accidentally author a change like this into the wrong layer, and the Render Settings panel gives no sign that it happened.
PTDenoise.zip (5.4 MB)
