Hello, I’m trying to install the CUDA Tookit in windows 8.1 to use with Anaconda, but I’ve got this warning:
" The NVIDIA installer needs to add a path to the %PATH% environment variable; however, doing so would exceed
the maximum length possible for this variable. After the installation has been completed, please shorten the
%PATH% environment variable. And then prepend below mentioned paths to the %PATH% environment variable after the installation, or else try the installation again.
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\libnvvp;
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\lv10.1\bin;
So, what does it means? what I have to do? I tried the installation again and got the same message.
If the path exceed the maximum length possible for a varible, why NVIDA use that path?
Thank you for the help.
