Pathtraced Renderer Fails in Omniverse Container
I cannot use the pathtraced renderer in the OV Replicator container ov-synthetic-data-generation:0.0.16-beta.
I am using scripts that need to use the pathtraced rendereder as follows
rep.settings.set_render_pathtraced(samples_per_pixel=64)
When I attempt to call rep.settings.set_render_pathtraced(samples_per_pixel=64) or rep.settings.set_render_pathtraced() I get the following Optix internal error.
[Error] [rtx.optixdenoising.plugin] [Optix] [DENOISER] Unable to load denoiser weights
[Error] [rtx.optixdenoising.plugin] optixDenoiserCreate(m_optixCtx, temporal ? OPTIX_DENOISER_MODEL_KIND_TEMPORAL_AOV : OPTIX_DENOISER_MODEL_KIND_AOV, &denoiserOptions, &denoiser) failed. Optix Error: OPTIX_ERROR_INTERNAL_ERROR.
Internal error
I expect these calls to work as this how they are described in the API doc and I am succefully using other methods of rep.settings.
My system:
Driver Version : 535.86.05
CUDA Version : 12.2
Bumping this, we need simulations with realistic lighting in the Replicator container. @dennis.lynch any ideas?
you need to map it from disk its a driver issue:
-v /usr/share/nvidia/nvoptix.bin:/usr/share/nvidia/nvoptix.bin
Thank you @Turowicz - this fixed the issue!
Also you are using a SUPER obsolete container, go with nvcr.io/nvidia/isaac-sim:4.0.0 for replicator workflows.
