This is the same exact scene shown using Raytracing and Pathtracing. Do you need to re-light your scene when using Pathtracing? Are there any other tricks you need to know when setting up a scene for Pathtracing?
Raytracing:
Pathtracing:
Raytracing:
Pathtracing:
Re-lighting for Path-tracer mode is not necessary.
You may try the following settings and then compare Real-Time Ray-tracer (RT) with Path-tracer mode (PT).
RTX Settings β Real-Time Renderer β Ray Tracing Tab β Direct Lighting Section β Enable Sampled Direct Lighting = On
RTX Settings β Real-Time Renderer β Ray Tracing Tab β Indirect Diffuse Lighting β Ambient Light Intensity = 0.0
Let us know,
Hi, thanks for the quick response. I tried those settings but they donβt seem to affect the path-tracer, only the ray-tracer. The Ambient Light Intensity setting definitely makes the scene darker when in RTX Real-Time mode, but has no effect in RTX Path-Traced mode.
Can you post a render comparison between PT and RT with the above settings?
Hi @jholbrook ,
Could you post a small sample of the scene for us to look at?
