Pause recording to a file, start once a spefic event is detected
I have setup a pipeline in Deepstream with python to write output from nvdsosd element.
I have a queue
queue1 = Gst.ElementFactory.make("queue", "queue1")
and then the rest of the elements necessary to record to mp4 file
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
capsfilter1 = Gst.ElementFactory.make("capsfilter", "capsfilter1")
capsfilter1.set_property("caps",
  Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA"))
and so on.
Is there a simple way I could cache about 3-4 seconds of my stream inside the queue and start / stop recording depending on an event detected upstream (by nvinfer plugin)?
smart video record is a c lib, Smart Video Record — DeepStream 6.1.1 Release documentation, deepstream-testsr is a sample.
need to do python bindings, deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
I know about this library, I was hoping if there was an easy way to implement it’s functionality using existing plugins for Python.
no this kind of plugin.
