I am using smart record in a custom application which is based on deepstream-test3. I use RTSP sources and have sync=false on my sinks and live-source=1 on the streammuxer.
I have connected the smart record bin prior to decoding (exactly the same as in the deepstream-test5 sample).
I notice that in my recorded files there is often a small pause in playback. This pause seems to always occur around the Smart Record “startTime” value.
For example: If I have smart record (SR) configured with a startTime of 3 seconds. I get the pause around the 3s mark. If I configure SR with a startTime of 5 seconds I will get the pause at the 5 sec mark.
If I configure 10 sec as the startTime I get the pause at the 10 second mark.
So it looks like this pause is somehow linked to SmartRecords startTime parameter, which I believe is the queue size used inside the SR bin. Why would this be causing pauses and what would you suggest to get around it?
Here is a sample mp4 file showing the pause at approx 3s in: Dropbox - File Deleted
ps. I notice that if 3 or 4 files record one after the other - it seems to be only the first one that gets the pause.
• Hardware Platform (Jetson / GPU) Nano, NX
• DeepStream Version 5.0GA
