Pb of installation of nvidia-glG05.460.39 on opensuse 15.2
I have installed the opensuse 15.2 on a PC without the Nvidia Quadro P620 Card
After I installed the latest drivers with this command line :
zypper addrepo – refresh https.//donwload.nvidia.com/opensuse/leap/45.2 nvidia
zypper in nvidia-gl05
I put the nvidia Quadro P620 on the PC
When I started the PC , I have a black screen
After 1 min , I arrive to pass on a text console with Ctrl + F1
When I try to start x server with starts , the server X failed.
I try to log me in root and start the server x with startx, the starts runs
The driver seems to be loaded because when I enter a lsmod command, I can see the nvidia drivers.
I don’nt show error about nvidia when I enter dmesg
Do you have an idea why the startx doesn’t run on a no root account
Please check if your user(s) are meber of the video group.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
My user are not a member of video group
I had my user to videao group.
Same effect
nvidia-bug-report.log.gz (1.2 MB)
Please post the output of
ls -l /dev/nvidia*
Please also check if the user gdm is member of the video group.
The gdm is well in the group video
The result of ls command ilsnvidiat (479 Bytes) s in the attach file lsnvida.txt
dbus-daemon[1962]: [session uid=461 pid=1962] Activating service name='org.freedesktop.systemd1' requested by ':1.0' (uid=461 pid=1948 comm="/usr/lib/gdm/gdm-x-session gnome-session --autosta")
 [session uid=461 pid=1962] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Unable to register display with display manager
Please check if pam_systemd.so is in /etc/pam.d/common-session
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=873199#17
Yes , it is in file common-session
For information , the Xorg.log who can see in the nbug-repport corresponds at two try who I can have the server x:
The first with starts x in root
the second with uncommant WaylandEnable in the /etc/gdm/custom.conf
In the second case, i have a log screen but i can log with my account
For you information , to day , I do an other test:
First , I add my user in group video like you suggest above
Second, I decomment the line WayLandEnable=false in the custom.conf in /etc/gdm directory
In this case, startx is lauched corerctly and I can have access to the login screen.
Is it a normal ?
