When intalling the pb3.8 with singularity, an unexpected error “/dssg doesn’t exist in the container”. Here is a screenshot.
PS: The host OS is CentOS 8.3.2011.
Thanks .
Thanks .
Hey @lkuang,
It looks like it’s having troubling mounting to that location. Can you share the command you used to run the installer and can you maybe try to ls that mount directory (/dssg/home/…) to make sure it exists.
Hi @gburnett,
Thanks for you relpy.
The screenshot shows the installation command (cmd), the directory, etc.
The /dssg is actually the physical directory.
It is confirmed the singularity setup make the container mount the directory automatically. After unseting it, now parabricks can be installed correctly.
