I have just faced with a problem working with a Jetson AGX Orin Developer Kit, P3737 carrier borad, LI-JAG-ADP-GMSL2-8CH GMSL2 board and ar0234 sensors. Jetpack version is 36.3, built from sources with no changes. tegra234-p3737-camera-dual-hawk-ar0234-e3653-overlay.dts
is selected as a DTS overlay. I have this logs during the boot process:
[ 4.148089] serial-tegra 3100000.serial: TX in PIO mode
[ 4.148147] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 4.148630] serial-tegra 3110000.serial: RX in PIO mode
[ 4.148634] serial-tegra 3110000.serial: TX in PIO mode
[ 4.148669] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 207, base_baud = 0) is a TEGRA_UART
[ 4.150970] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.150980] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.151430] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.156861] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.166582] pca954x 2-0070: probe failed
[ 4.167514] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 4.173590] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.181390] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 4.186189] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 4.192651] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.199606] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.236639] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 4.240695] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 4.243907] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 4.244968] sdhci-tegra 3400000.mmc: Adding to iommu group 3
Seems like something went wrong with PCA954x
i2c multiplexer initialization and it might be a reason why I can not see any signs of max96712
and ar0234
modules probes.
Can anybody helps me with that, are there any reasons why pca954x
probe can fails?
