PCAN-USB on the jetson nano
1-) I want a transmit a message to car using pcan-usb converter with jetson nano but i couldn’t figure out what should I install for driver and code part. Have you ever experience pcan-usb?
2-) How to reach kernel config in jetson nano?
I tried this : grep PEAK_ /boot/config-uname -r
grep: /boot/config-4.9.140-tegra: No such file or directory
If you know the answer of first question, Can you explain step by step?
Thanks for help.
