HI NV
Are the rules in the following table related to the wiring of MIPI related to PCB boards?,
Is it calculated based on the EM-370 (Z) - 15 sheet currently used by ORIN?
If we use plates with less loss, can the maximum wiring length be extended.
Panasonic M890K is the plate with less loss. Can we have a longer routing?
Hi, you can use flight time (delay) as the limit to calculate the length with different PCB material.
