I am trying to use a edgeTPU module using a PCI on TX2.
Reading this specification, it seems like the TX2 conforms to PCI Express Base Specification Revision 2.0 - section 4.3.
Coral says:
Is it incompatible? I have read that the TX2 has interrupts on the PCI, but does it requires 3.0 PCI specs to work?
I have, but the custom carrier board used with the TX2 hasn’t been finalised for it yet, so was wondering if the problem was coming from TX2 itself too…
I know Xavier really boosted things and handles up to PCIe gen. 4. From what I can tell the TX2 only supports gen. 2. See: https://elinux.org/Jetson_TX2
I also have to add that actually achieving a particular generation’s speed on a PCIe bus requires proper design. If signal quality is not sufficient, then the bus will slow down to a slower generation’s speed. Not many devices actually achieve gen. 4, but gen. 3 is commonly reached (although there are a number of devices which might end up throttling back to gen. 2).
