Can I run the PCI Test Function or any similar test in the Jetson AGX Orin? I would like to develop the endpoint driver, but I can’t connect a RP for now, than it looks like a good solution. But I’m not able to find the pci_epf_nv_test.c or pci_epf_test.c files.
I checked both documentation. I would like to enforce my question: Is the pci_epf_nv_test or pci_epf_test available for 36.3.0 L4T version?? I’m not able to find it.
However, is it possible to implement the same function (epf dma) on this version? Probably, the driver would be based on this pci_epf_nv_test. I want to know if the driver was removed because the test or the feature is incompatible with the version.
