Hallo, I just bought this PCI USB card https://www.delock.com/produkt/89325/pdf.html?sprache=en, and I try to make it work with AGX Xavier. I mount it on the PCI slot but any usb device i plug on it does not seem to be recognized. Could you helo me to make this work ?
you might need external power probably?
1 x internal SATA 15 pin power connector
we used power supply of a desktop computer with similar board
So u had the same issue until you used a power supply ?
exactly!
PCI usb wouldn’t work until we attached SATA power
OK I’ll try it and I will let you know. Thank you.
Thank you a lot it worked perfectly.
