Ok great, thank you. I will test.
Ohh sorry, yes, the IP adresse is “192.168.3.10”.
I just have one camera. Actually, I can use the camera in single Gige or Dual Gige. In single Gige, the camera is able to send an image to the jetson every 400ms. In dual Gige, every 200ms, that is why it is very interesting for my application (I am working on image processing, and I need to acquire image as fast as possible).
The camera is connected directly to the jetson. I don’t use a host computer to develop (not yet, but the most comprehensive tools seems to be nsight nvidia, and I will have to use the GPU …).
So, ethernet port of the jetson is connected to the camera directly. As the camera has 2 ethernets ports, thanks to the PCI, I will have to ethernet connected from the jetson to the camera (I have 5 ethernets ports on the jetson with the PCI). So I don’t need to think about the network topology, and the jetson is connected to internet by wifi.
In single Gige, to connect the camera I just need to enter the following command :
sudo ifconfig eth0 192.168.3.9 netmask 255.255.255.0 mtu 9000
And when I have tried to connect the camera in dual Gige, the manufacturer give the following command :
ip link add mybond type bond
ip addr add dev mybond 192.168.3.1/24
ip link set mybond up
ip link set eth4 down
ip link set eth4 master mybond
ip link set eth3 down
ip link set eth3 master mybond
ip link set mybond mmtu 90000
The output of the first command is :
sudo ip link add mybond type bond
[sudo] password for jetson:
#RTNETLINK answers: Operation not supported
I tried to connect the camera with an ethernet port from the PCI, and it works well.
I hope that my situation is more clear now.
Thank you !
