Using NVIDIA ORIN NX, a PCIE4.0X4 to USB 3.0 adapter card was used to transfer out 4 USB ports. After inserting a USB drive, the system found 4 USB 3.0 devices, but the USB drive could not be read. After preliminary investigation, the USB driver problem was ruled out, which may be more related to the NVIDIA platform. Can you help identify the problem?
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Duplicated with PCIe4.0X4转USB3.0o - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
