Using NVIDIA ORIN NX, a PCIE4.0X4 to USB 3.0 adapter card was used to transfer out 4 USB ports. After inserting a USB drive, the system found 4 USB 3.0 devices, but the USB drive could not be read. After preliminary investigation, the USB driver problem was ruled out, which may be more related to the NVIDIA platform. Can you help identify the problem?
Related topics
Topic | Replies | Views | Activity | |
PCIe 4.0X4 to USB 3.0 conversion | 3 | 24 | January 23, 2025 | |
PCIe4.0X4转USB3.0o | 3 | 22 | January 23, 2025 | |
PCIe USB hub with an m.2 adaptor | 7 | 1218 | August 8, 2023 | |
Can the jetson Orin Nx use three usb3.0? | 16 | 180 | June 12, 2024 | |
Orin NX work as a PCIe device | 3 | 612 | March 7, 2023 | |
AGX ORIN usb3.0 does not work or is recognized as 2.0 on USB1 | 4 | 92 | August 13, 2024 | |
ORIN NX Using 3-way USB for device tree adaptation | 4 | 217 | April 25, 2024 | |
Orin NX add USB3.0 to port USB2.0 | 10 | 1585 | March 8, 2023 | |
About Orin NX USB3.2 | 4 | 1182 | April 12, 2023 | |
USB device problem with Orin NX | 7 | 780 | March 21, 2024 |
