Dear NVIDIA Support Team @ShaneCCC,
I am encountering continuous PCIe Bus Errors when using a Jetson Orin NX 16GB module on development carrier board. The system logs show repeated messages like:
PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00e5(Receiver ID)
These errors appear continuously & facing issue to boot the SOM. However, when I swap the module with a Jetson Xavier NX (using the same carrier board and setup), the system functions without any such errors.
Based on the provided context, I’ll attempt to provide a comprehensive answer to the question.
The issue described involves a Jetson Orin NX 16GB module on a development carrier board, which is experiencing continuous PCIe Bus Errors. The system logs show repeated messages indicating a corrected physical layer error with a receiver ID of 00e5. These errors prevent the system from booting properly.
However, when the module is swapped with a Jetson Orin Nano module ( exact model not specified) on the same carrier board and setup, the system functions without any errors.
To address this issue, let’s consider the following points:
- Module compatibility: The Jetson Orin NX 16GB module and the Jetson Orin Nano module are both part of the Jetson Orin NX Series and Jetson Orin Nano Series, respectively. Both series are compatible with the Jetson Orin Nano carrier board. However, it’s essential to verify that the specific modules used are compatible with the carrier board and each other.
- PCIe Bus Errors: The PCIe Bus Errors indicate a problem with the communication between the module and the carrier board. This could be related to the module’s configuration, the carrier board’s design, or the PCIe lane configuration.
- Carrier board design: The fact that the system functions without errors when using the Jetson Orin Nano module suggests that the carrier board design might be compatible with this specific module. However, it’s possible that the carrier board’s design or configuration needs to be adjusted to accommodate the Jetson Orin NX 16GB module.
- Module configuration: The MODULE_ID setting (Module ID 3767) might be relevant in this case, as it indicates the capability of the module. It’s possible that the Jetson Orin NX 16GB module requires a specific configuration or setting that is not being met, leading to the PCIe Bus Errors.
- Comparison with similar issues: The provided context mentions several issues related to PCIe, device trees, and board design. While these issues might not be directly related to the problem at hand, they could provide valuable insights into potential solutions. For example, the “Enabling C7 PCIe on Jetson Orin Nano issue” and “Lan7430 issue” might be relevant when troubleshooting PCIe-related problems.
To resolve the issue, I recommend the following steps:
- Verify the compatibility of the Jetson Orin NX 16GB module with the carrier board and ensure that the module is properly configured.
- Check the carrier board’s design and configuration to ensure it is compatible with the Jetson Orin NX 16GB module.
- Investigate the MODULE_ID setting and ensure it is correctly configured for the Jetson Orin NX 16GB module.
- Consult the NVIDIA documentation and forums for similar issues and potential solutions.
- If possible, try using a different carrier board or module to isolate the problem and determine if it’s specific to the Jetson Orin NX 16GB module or the carrier board.
By following these steps, you should be able to identify and potentially resolve the issue causing the PCIe Bus Errors on the Jetson Orin NX 16GB module.
Thanks ~0827
What kind of device is in use here?
Is Xavier NX and Orin NX using same version of rel-35.x jetpack?
