Hi NV Support Team
Which register can indicate PCIe Link Status / Speed.
Does this is correct reigister: PCIE_X8_RC_PF0_PCIE_CAP_LINK_CAPABILITIES2_REG_0
page 6034 from TRM.
Yutai
Hi NV Support Team
page 6034 from TRM.
Yutai
lspci command shall already tell you the link speed. No need to use register dump to check.
Hi liyutai:
have you test RC EP PCIe communication?
Hi Wayne
I use ispici get the below log:
LnkSta: Speed 16GT/s (ok), Width x8 (ok)
That means PCIe working in PCIe 4 mode 16GT/s, Correct?
Yutai
Yes, I have test it . it work well
hi liyutai:
below is my step:
1.in p3701.conf.common
ODMDATA=βgbe-uphy-config-22,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g,hsstp-lane-map-3β; to ODMDATA=βgbe-uphy-config-22,nvhs-uphy-config-1,hsio-uphy-config-0,gbe0-enable-10g,hsstp-lane-map-3β
2.# sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
3.use this patch for ep:
diff --git a/kernel/kernel-5.10/drivers/pci/controller/dwc/pcie-tegra194.c b/kernel/kernel-5.10/drivers/pci/controller/dwc/pcie-tegra194.c
index 7fde1a4d6..981bbac02 100644
--- a/kernel/kernel-5.10/drivers/pci/controller/dwc/pcie-tegra194.c
+++ b/kernel/kernel-5.10/drivers/pci/controller/dwc/pcie-tegra194.c
@@ -2164,7 +2164,9 @@ static void tegra_pcie_enable_legacy_interrupts(struct pcie_port *pp)
val |= APPL_INTR_EN_L1_8_INTX_EN;
val |= APPL_INTR_EN_L1_8_AUTO_BW_INT_EN;
val |= APPL_INTR_EN_L1_8_BW_MGT_INT_EN;
+#if 0
val |= APPL_INTR_EN_L1_8_EDMA_INT_EN;
+#endif
if (IS_ENABLED(CONFIG_PCIEAER))
val |= APPL_INTR_EN_L1_8_AER_INT_EN;
appl_writel(pcie, val, APPL_INTR_EN_L1_8_0);
@@ -3569,9 +3571,11 @@ static void pex_ep_event_pex_rst_deassert(struct tegra_pcie_dw *pcie)
val |= APPL_INTR_EN_L1_0_0_RDLH_LINK_UP_INT_EN;
appl_writel(pcie, val, APPL_INTR_EN_L1_0_0);
+#if 0
val = appl_readl(pcie, APPL_INTR_EN_L1_8_0);
+#endif
if (pcie->enable_cdm_check) {
val = appl_readl(pcie, APPL_INTR_EN_L0_0);
@@ -3880,6 +3884,7 @@ tegra_pcie_ep_get_features(struct dw_pcie_ep *ep)
return &tegra_pcie_epc_features;
+#if 0
/* Reserve BAR0_BASE + BAR0_MSI_OFFSET of size SZ_64K as MSI page */
static int tegra_pcie_ep_set_bar(struct dw_pcie_ep *ep, u8 func_no,
struct pci_epf_bar *epf_bar)
@@ -3903,11 +3908,11 @@ static int tegra_pcie_ep_set_bar(struct dw_pcie_ep *ep, u8 func_no,
return 0;
+#endif
static struct dw_pcie_ep_ops pcie_ep_ops = {
.raise_irq = tegra_pcie_ep_raise_irq,
.get_features = tegra_pcie_ep_get_features,
- .set_bar = tegra_pcie_ep_set_bar,
static int tegra_pcie_config_ep(struct tegra_pcie_dw *pcie,
4.start ep exec
# cd /sys/kernel/config/pci_ep/
# mkdir functions/pci_epf_tvnet/func1
# echo 16 > functions/pci_epf_tvnet/func1/msi_interrupts
# ln -s functions/pci_epf_tvnet/func1 controllers/141a0000.pcie_ep/
# echo 1 > controllers/141a0000.pcie_ep/start
5 start rc
and lspci see device id0x2296.
On the endpoint device: ifconfig eth1 up
On the root port system: ifconfig eth1 up
On the endpoint device: ifconfig eth1 192.168.2.1
On the root port system: ifconfig eth1 192.168.2.2
do you have any suggest,thanks
Hi
I need forward your step to our SW colleague to check.
Yutai
