I think M.2M should work. (Designed identically to NVIDIA Reference Schematic)
M.2M PCIe H/W connection (M.2E not used) PCIe Usage: PCIe Block#0, Controller #4, Lane#4~#7
When I enter the “lspci” command in the terminal, there is no output.
M.2M Signal oscilloscope measurement level.
M.2M Pin 69: floating state (PCIe)
PERST# (PCIE4_RST_N): Low state
PEWAKE# (PCIE_WAKE_N): High state
SMB_DATA, SMB_CLK: Serial Resistor No STUFF
SUSCLK (32KHz): 32KHz input normal
CLKREQ# (PCIE4_CLKREQ_N): Low state
I don’t know what does that mean “should work”
==> The M.2M related H/W circuit is designed identically to the NVIDIA-released circuit. So, I think this function should basically work normally.
Do you have the real NVIDIA devkit to test the M.2 card instead of “you think”?
==> I have an NVIDIA devkit (Third-party product), but it is defective so I can’t test it with it.
This issue has been resolved.
By replacing NVMe, Access became successful.
It is believed that the cause was a defective NVMe.
Coincidentally, there were 3 NVMes, but 2 out of 3 were defective.
