I tried Pcie card on windows and linux in x86 it is working.But i tried in arm64 i am getting the following
I tried to get my base address of Pcie i got it After that pci_resource_start().Before that i checked it is port mapped or io mapped by if (bar_flags & IORESOURCE_IO) i got it port io and io size i got 256 bytes.from 0x1000 to 0x10ff .So from that i need to access the register values from the pci configuration by byte=ioread8(baseaddr+0x74);.After that i am getting these errors
rtnic: map_ioaddr: 0xf596000
[ 162.292784] CPU3: SError detected, daif=140, spsr=0x80000045, mpidr=80000101, esr=bf000000
[ 162.293996] CPU0: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000100, esr=bf40c000
[ 162.294001] CPU5: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000103, esr=bf40c000
[ 162.294005] CPU4: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000102, esr=bf40c000
[ 162.295540] ROC:IOB Machine Check Error:
[ 162.295548] Address Type = Secure DRAM
[ 162.295603] Address = 0x0 (Unknown Device)
Can you help that Pcie supported by jetson in arm64 or not if it is supported then how i can access the register configuration space from pcie through Jetson tx2.
