I’m trying to get a marvell 9230 SATA controller to work on L4T R28.1
$ uname -a
Linux tegra-ubuntu 4.4.38-tegra #1 SMP PREEMPT Thu Jul 20 00:41:06 PDT 2017 aarch64 aarch64 aarch64 GNU/Linux
The controller is detected by the system:
$ sudo lspci -vvv -s 01:00.0
01:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9230 PCIe SATA 6Gb/s Controller (rev 11) (prog-if 01 [AHCI 1.0])
Subsystem: Marvell Technology Group Ltd. 88SE9230 PCIe SATA 6Gb/s Controller
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 368
Region 0: I/O ports at 1020
Region 1: I/O ports at 1030
Region 2: I/O ports at 1028
Region 3: I/O ports at 1034
Region 4: I/O ports at 1000
Region 5: Memory at 13010000 (32-bit, non-prefetchable)
Expansion ROM at 13000000 [disabled]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
Address: 00000000 Data: 0000
Capabilities: [70] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <1us, L1 <8us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <512ns, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x2, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [e0] SATA HBA v0.0 BAR4 Offset=00000004
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
But none of the drives are detected.
Here’s the kernel log:
$ dmesg | grep -i PCI
[ 0.275584] platform 1003000.pcie-controller: domain=ffffffc0fa25be18 allocates as[0]=ffffffc0fa14c4b8
[ 0.460859] PCI: CLS 0 bytes, default 128
[ 0.499841] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.499890] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.499937] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.499982] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.500027] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.503446] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.508081] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.508150] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.508176] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 3.631281] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 3.631300] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 3.631317] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 3.631334] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 3.631351] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 3.637159] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 3.637397] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 3.638492] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 3.640604] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 4.087572] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.496064] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.905951] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.908002] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 4.908164] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 4.908167] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 4.908170] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 4.908173] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.908176] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 4.908196] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 4.908270] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.908435] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.908539] pci 0000:01:00.0: [1b4b:9230] type 00 class 0x010601
[ 4.908580] pci 0000:01:00.0: reg 0x10: [io 0x8000-0x8007]
[ 4.908593] pci 0000:01:00.0: reg 0x14: [io 0x8040-0x8043]
[ 4.908606] pci 0000:01:00.0: reg 0x18: [io 0x8100-0x8107]
[ 4.908618] pci 0000:01:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 4.908631] pci 0000:01:00.0: reg 0x20: [io 0x800000-0x80001f]
[ 4.908644] pci 0000:01:00.0: reg 0x24: [mem 0x00900000-0x009007ff]
[ 4.908658] pci 0000:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 4.908710] pci 0000:01:00.0: PME# supported from D3hot
[ 4.908846] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.908871] pci 0000:00:01.0: BAR 8: assigned [mem 0x13000000-0x130fffff]
[ 4.908874] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 4.908879] pci 0000:01:00.0: BAR 6: assigned [mem 0x13000000-0x1300ffff pref]
[ 4.908882] pci 0000:01:00.0: BAR 5: assigned [mem 0x13010000-0x130107ff]
[ 4.908888] pci 0000:01:00.0: BAR 4: assigned [io 0x1000-0x101f]
[ 4.908894] pci 0000:01:00.0: BAR 0: assigned [io 0x1020-0x1027]
[ 4.908900] pci 0000:01:00.0: BAR 2: assigned [io 0x1028-0x102f]
[ 4.908905] pci 0000:01:00.0: BAR 1: assigned [io 0x1030-0x1033]
[ 4.908911] pci 0000:01:00.0: BAR 3: assigned [io 0x1034-0x1037]
[ 4.908917] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 4.908920] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 4.908925] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 4.909055] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 4.909057] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.909062] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 4.909126] aer 0000:00:01.0:pcie02: service driver aer loaded
[ 4.909226] tegra-pcie 1003000.pcie-controller: speed change : Gen-1 -> Gen-2
I’ve seen the post from https://devtalk.nvidia.com/default/topic/969972/sata-controller-marvell-9230-doesn-t-work-on-tx1/ - but the OP was using the 3.10 kernel.
It looks to me that there’s no driver loaded - is the driver enabled in the kernel config? If not, what config option should I enable?
$ zcat /proc/config.gz | grep -i ahci
# CONFIG_SATA_AHCI is not set
# CONFIG_SATA_AHCI_PLATFORM is not set
# CONFIG_AHCI_CEVA is not set
CONFIG_SATA_AHCI_TEGRA=y
# CONFIG_AHCI_TEGRA is not set
# CONFIG_AHCI_QORIQ is not set
# CONFIG_SATA_ACARD_AHCI is not set
