How can I force the enumeration of PCI devices without Xavier shutting down? When I shut down Xavier and restart it with a reset signal, I can’t scan connected PCI devices. But if I choose to restart Xavier, I can scan my PCI device normally,
Then I want to use the echo 1 > / sys / bus / PCI / rescan command to re enumerate the PCI devices, but I find it still can’t do that
So, is there any way to solve this problem?I think after the reset signal is sent out and Xavier is started, I can still scan the relevant PCI devices
Hi @Sebastian_z
Your query is not clear to me. Can you describe in more detail what you are trying to do?
