I’m attempting to connect an SATA3 SSD at a full 6Gbps. Since the native SATA controller on the TX only supports SATA2, I thought I might get the speed I’m after by using an inexpensive PCIe SATA3 controller. Unfortunately, it doesn’t seem to be working.
The manual for this particular device http://www.sybausa.com/index.php?route=product/product/download&download_id=761 claims that kernels all the way back to 2.6.19 should support its chipset out of the box when “ata_generic.all_generic_ide=1” is added to the boot .conf file, but that didn’t seem to have any effect when added to the APPEND line of the default /boot/extlinux/extlinux.conf
lspci -vvv seems to correct identify the device and applies the drivers that I would expect:
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13000000-130fffff
Prefetchable memory behind bridge: 0000000020000000-00000000200fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v0] #00
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
Kernel driver in use: pcieport
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. Device 1060
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 547
Region 0: I/O ports at 1020
Region 1: I/O ports at 1030
Region 2: I/O ports at 1028
Region 3: I/O ports at 1034
Region 4: I/O ports at 1000
Region 5: Memory at 13000000 (32-bit, non-prefetchable)
[virtual] Expansion ROM at 20000000 [disabled]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: 7ef8a000 Data: 0000
Capabilities: [78] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [80] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <1us, L1 <8us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s unlimited, L1 <2us
ClockPM- Surprise- LLActRep- BwNot-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Kernel driver in use: ahci
But if I’m interpreting dmesg correctly, the TX was never able to successfully communicate with the controller (or its attached drive) no matter how far back it throttled its attempted connection speed:
[ 9.500651] ALSA device list:
[ 9.505186] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 11.510608] ata2.00: qc timeout (cmd 0xec)
[ 11.516316] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 12.070614] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 12.079979] mc-err: [mcerr] (0) csw_afiw: EMEM address decode error
[ 12.087926] mc-err: [mcerr] status = 0x20010031; addr = 0x7ef8a000
[ 12.095959] mc-err: [mcerr] secure: no, access-type: write, SMMU fault: none
[ 22.070606] ata2.00: qc timeout (cmd 0xec)
[ 22.076407] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 22.084238] ata2: limiting SATA link speed to 3.0 Gbps
[ 22.640603] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 320)
[ 22.650043] mc-err: [mcerr] (0) csw_afiw: EMEM address decode error
[ 22.658123] mc-err: [mcerr] status = 0x20010031; addr = 0x7ef8a000
[ 22.666299] mc-err: [mcerr] secure: no, access-type: write, SMMU fault: none
[ 52.640598] ata2.00: qc timeout (cmd 0xec)
[ 52.646543] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 53.200674] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 320)
[ 53.208818] md: Waiting for all devices to be available before autodetect
Although these failures only occur with the SSD connected, no entry for my ssd appeared within /dev.
Does anyone have any insight on what might be going wrong here?
