Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hello averyone
I wanted to ask if anyone has made any speed/latency measurements over PCIe and Ethernet?
Is there any recommended way of measuring transfer speed?
And perhaps most importantly, do calculations based on standard PCIe gen 3 transfer speeds of 8 GT/sec or 8 Gbits/sec apply here?
Thanks in advance for your reply
Dear @erick.vieyra,
We are checking internally on this. Do you have any use case that can be shared?
Thanks for your reply @SivaRamaKrishnaNV !
We do not have a specific use case at the moment. Quite the opposite: We are trying to evaluate the capabilities of a Xavier to Xavier comm using PCIe in order how we can architect our system.
Thanks for checking this internally, we are eagerly awaiting for more insights!
Dear @erick.vieyra,
we measure Ethernet (10G) Performance which is hosted on PCIe.
As I understand, the use case is to check Xavier - Xavier communication performance.
We measure 10G(via HSD port) inter Tegra communication. To get the numbers on your side, Could you check the below steps.
set MTU:9000 on both Xavier-A and Xavier-B like below using below command.
sudo ifconfig <<enP*p1s0>> mtu 9000 txqueuelen 1000 up
Execute "ifconfig [enP*p1s0] " to check whether mtu is set or not.
Run iperf3 like below
On Tegra-A: iperf3 -c [Tegra-B ip] -l512k -t 120
On Tegra-B: iperf3 -s
Those instructions are definitely useful but we are trying to get close to the theoretical limit of a PCIe 4xlane connection.
We followed the steps in Non-Transparent Bridging and PCIe Interface Communication and we are trying to to get higher speed using that configuration. The hardware path that we are using is marked as B in the image attached.
Hello @SivaRamaKrishnaNV
I tried out the new settings and command on the PCIe NTB connection and the results are lower performance than before:
... more results before...
[ 4] 102.00-103.00 sec 215 MBytes 1.81 Gbits/sec 0 2.62 MBytes
[ 4] 103.00-104.01 sec 225 MBytes 1.87 Gbits/sec 0 2.62 MBytes
[ 4] 104.01-105.01 sec 223 MBytes 1.87 Gbits/sec 36 1.83 MBytes
[ 4] 105.01-106.01 sec 220 MBytes 1.85 Gbits/sec 0 1.83 MBytes
[ 4] 106.01-107.01 sec 220 MBytes 1.85 Gbits/sec 0 1.83 MBytes
[ 4] 107.01-108.00 sec 220 MBytes 1.86 Gbits/sec 0 1.83 MBytes
[ 4] 108.00-109.02 sec 225 MBytes 1.86 Gbits/sec 0 1.83 MBytes
[ 4] 109.02-110.00 sec 220 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 110.00-111.01 sec 225 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 111.01-112.00 sec 220 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 112.00-113.01 sec 225 MBytes 1.88 Gbits/sec 0 1.83 MBytes
[ 4] 113.01-114.01 sec 225 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 114.01-115.00 sec 220 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 115.00-116.02 sec 225 MBytes 1.86 Gbits/sec 0 1.83 MBytes
[ 4] 116.02-117.01 sec 220 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 117.01-118.02 sec 225 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 118.02-119.00 sec 220 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ 4] 119.00-120.01 sec 225 MBytes 1.87 Gbits/sec 0 1.83 MBytes
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-120.01 sec 25.5 GBytes 1.82 Gbits/sec 36 sender
[ 4] 0.00-120.01 sec 25.5 GBytes 1.82 Gbits/sec receiver
