We are trying to access FPGA PCIe card with Key M of Xaiver NX.
The carrier board is customized and I didn’t do something for kernel yet.
We would try to do following link.
Befor that, I want to check is there any problem.
And I’m not sure current status is OK or not.
Please, check the status.
- dmesg | grep pci
[ 0.724300] iommu: Adding device 14160000.pcie to group 0
[ 0.724987] iommu: Adding device 141a0000.pcie to group 1
[ 1.860764] ehci-pci: EHCI PCI platform driver
[ 1.860809] ohci-pci: OHCI PCI platform driver
[ 12.116244] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 12.117420] OF: PCI: host bridge /pcie@14160000 ranges:
[ 12.632123] tegra-pcie-dw 14160000.pcie: link is down
[ 12.632503] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 12.632511] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 12.632518] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 12.632523] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 12.632528] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 12.632557] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 12.632705] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 12.633236] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 12.633259] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.633616] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 12.633623] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 12.633739] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 12.633908] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 12.633995] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 12.634079] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 12.634174] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 12.635507] tegra-pcie-dw 14160000.pcie: PCIe link is not up...!
[ 12.636093] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 12.636373] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 12.636382] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 12.744732] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 12.852290] tegra-pcie-dw 141a0000.pcie: link is up
[ 12.852564] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 12.852572] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 12.852579] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 12.852584] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 12.852589] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 12.852615] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 12.852746] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 12.853346] pci 0005:01:00.0: [10ee:7014] type 00 class 0x058000
[ 12.853529] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x000007ff]
[ 12.854274] pci 0005:01:00.0: PME# supported from D0 D1 D2 D3hot
[ 12.865589] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 12.865597] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f400007ff]
[ 12.865623] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 12.865631] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 12.865648] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.865702] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 12.865935] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 12.865940] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 12.865946] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 12.866076] aer 0005:00:00.0:pcie002: service driver aer loaded
- lspci -vv
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 35
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
Memory behind bridge: 40000000-400fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: <access denied>
Kernel driver in use: pcieport
0005:01:00.0 Memory controller: Xilinx Corporation Device 7014
Subsystem: Xilinx Corporation Device 0007
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 255
Region 0: Memory at 1f40000000 (32-bit, non-prefetchable) [disabled] [size=2K]
- lshw
