[b]Hello:
If i want add a PCIe to 10GB Ethernet IC, then the IC belong to ENDPOINT Device? Jetson AGX xavier PCIe should use ENDPOINT mode or Root Port mode? thanks
Best regard
Jetson Xavier PCIe controller can act as both root port and endpoint. Just need to do some configuration. The default mode is rp mode.
Yes, your 10GbE is working as a ep device.
