Attach full log
[Com COM30] (2019-06-12_134603).log (159 KB)
Hi Vidays
Do you have any update for this issue?
Please apply below two patches in the same order and try
Path-1:
diff --git a/drivers/pci/dwc/pcie-tegra.c b/drivers/pci/dwc/pcie-tegra.c
index ee5fbfa2f..1ac64450d 100644
--- a/drivers/pci/dwc/pcie-tegra.c
+++ b/drivers/pci/dwc/pcie-tegra.c
@@ -4540,10 +4540,6 @@ static int tegra_pcie_dw_runtime_resume(struct device *dev)
val |= APPL_PINMUX_CLKREQ_OUT_OVRD_EN;
val |= APPL_PINMUX_CLKREQ_OUT_OVRD;
writel(val, pcie->appl_base + APPL_PINMUX);
- /* Disable ASPM-L1SS adv as there is no CLKREQ routing */
- disable_aspm_l11(pcie); /* Disable L1.1 */
- disable_aspm_l12(pcie); /* Disable L1.2 */
/* update iATU_DMA base address */
@@ -4552,6 +4548,12 @@ static int tegra_pcie_dw_runtime_resume(struct device *dev)
reset_control_deassert(pcie->core_rst);
+ if (pcie->disable_clock_request) {
+ /* Disable ASPM-L1SS adv as there is no CLKREQ routing */
+ disable_aspm_l11(pcie); /* Disable L1.1 */
+ disable_aspm_l12(pcie); /* Disable L1.2 */
/* program to use MPS of 256 whereever possible */
pcie_bus_config = PCIE_BUS_SAFE;
@@ -4723,10 +4725,6 @@ static int tegra_pcie_dw_resume_noirq(struct device *dev)
@@ -4735,6 +4733,12 @@ static int tegra_pcie_dw_resume_noirq(struct device *dev)
tegra_pcie_dw_host_init(&pcie->pci.pp);
/* restore MSI interrutp vector*/
Patch-2:
index 1ac64450d..4cd746b8b 100644
@@ -58,8 +58,6 @@
#define APPL_PINMUX_CLKREQ_OVERRIDE BIT(3)
#define APPL_PINMUX_CLK_OUTPUT_IN_OVERRIDE_EN BIT(4)
#define APPL_PINMUX_CLK_OUTPUT_IN_OVERRIDE BIT(5)
-#define APPL_PINMUX_CLKREQ_OUT_OVRD_EN BIT(9)
-#define APPL_PINMUX_CLKREQ_OUT_OVRD BIT(10)
#define APPL_PINMUX_PEX_RST_IN_OVERRIDE_EN BIT(11)
#define APPL_CTRL (0X4)
@@ -4537,8 +4535,8 @@ static int tegra_pcie_dw_runtime_resume(struct device *dev)
val = readl(pcie->appl_base + APPL_PINMUX);
- val |= APPL_PINMUX_CLKREQ_OUT_OVRD_EN;
- val |= APPL_PINMUX_CLKREQ_OUT_OVRD;
+ val |= APPL_PINMUX_CLKREQ_OVERRIDE_EN;
+ val &= ~APPL_PINMUX_CLKREQ_OVERRIDE;
@@ -4722,8 +4720,8 @@ static int tegra_pcie_dw_resume_noirq(struct device *dev)
您好,我最近也在尝试PCIe主从连接设备,能否共享下您所使用的转接板,如果有链接就更好了,不胜感激!
