I am working on a debian 9.1 system with two GTX770’s installed in x16 slots. nvidia-smi returns that neither is capable of peer access but I couldn’t find a solution in existing forum posts. Both seem to have PHB connections and attatched to the same pcie controller, and I don’t think ACS is enabled.
nvidia-smi
| NVIDIA-SMI 387.26 Driver Version: 387.26 |
| 0 GeForce GTX 770 Off | 00000000:01:00.0 N/A | N/A |
| 34% 41C P8 N/A / N/A | 208MiB / 1998MiB | N/A Default |
| 1 GeForce GTX 770 Off | 00000000:05:00.0 N/A | N/A |
| 34% 36C P8 N/A / N/A | 13MiB / 1999MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
| 1 Not Supported |
lspci -t
-[0000:00]-+-00.0
+-02.0-[01]--+-00.0
| \-00.1
+-04.0-[02]----00.0
+-09.0-[03]----00.0
+-0a.0-[04]----00.0
+-0b.0-[05]--+-00.0
| \-00.1
+-11.0
+-12.0
+-12.2
+-13.0
+-13.2
+-14.0
+-14.1
+-14.2
+-14.3
+-14.4-[06]--
+-14.5
+-15.0-[07]----00.0
+-16.0
+-16.2
+-18.0
+-18.1
+-18.2
+-18.3
+-18.4
\-18.5
lspci -vvvv
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD9x0/RX980 Host Bridge (rev 02)
Subsystem: ASRock Incorporation RD9x0/RX980 Host Bridge
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
NUMA node: 0
Capabilities: [f0] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [c4] HyperTransport: Slave or Primary Interface
Command: BaseUnitID=0 UnitCnt=20 MastHost- DefDir- DUL-
Link Control 0: CFlE- CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b+
Link Config 0: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=16bit DwFcInEn- LWO=16bit DwFcOutEn-
Link Control 1: CFlE- CST- CFE- <LkFail+ Init- EOC+ TXO+ <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config 1: MLWI=8bit DwFcIn- MLWO=8bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Revision ID: 3.00
Link Frequency 0: [b]
Link Error 0: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability 0: 200MHz+ 300MHz- 400MHz+ 500MHz- 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz+ 1.4GHz- 1.6GHz- Vend-
Feature Capability: IsocFC+ LDTSTOP+ CRCTM- ECTLT- 64bA+ UIDRD-
Link Frequency 1: 200MHz
Link Error 1: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability 1: 200MHz- 300MHz- 400MHz- 500MHz- 600MHz- 800MHz- 1.0GHz- 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Error Handling: PFlE- OFlE- PFE- OFE- EOCFE- RFE- CRCFE- SERRFE- CF- RE- PNFE- ONFE- EOCNFE- RNFE- CRCNFE- SERRNFE-
Prefetchable memory behind bridge Upper: 00-00
Bus Number: 00
Capabilities: [40] HyperTransport: Retry Mode
Capabilities: [54] HyperTransport: UnitID Clumping
Capabilities: [9c] HyperTransport: #1a
Capabilities: [70] MSI: Enable- Count=1/4 Maskable- 64bit-
Address: 00000000 Data: 0000
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GFX port 0) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 25
NUMA node: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fd000000-fe0fffff
Prefetchable memory behind bridge: 00000000d0000000-00000000d9ffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [58] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #2, PowerLimit 75.000W; Interlock- NoCompl+
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible+
RootCap: CRSVisible+
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd+
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [b0] Subsystem: ASRock Incorporation RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GFX port 0)
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [190 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl- DirectTrans+
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Kernel driver in use: pcieport
Kernel modules: shpchp
00:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 0) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: fe600000-fe6fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
ExtTag+ RBE+
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
LnkSta: Speed 5GT/s, Width x2, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
Slot #4, PowerLimit 75.000W; Interlock- NoCompl+
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd+
Capabilities: [b0] Subsystem: ASRock Incorporation RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 0)
00:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 4) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 24
NUMA node: 0
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: fe500000-fe5fffff
ExtTag+ RBE+
LnkCap: Port #3, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
Slot #9, PowerLimit 75.000W; Interlock- NoCompl+
Capabilities: [b0] Subsystem: ASRock Incorporation RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 4)
00:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 5) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 26
NUMA node: 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fe400000-fe4fffff
ExtTag+ RBE+
LnkCap: Port #4, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
Slot #10, PowerLimit 75.000W; Interlock- NoCompl+
Capabilities: [b0] Subsystem: ASRock Incorporation RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 5)
00:0b.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD990 PCI to PCI bridge (PCI Express GFX2 port 0) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: fb000000-fc0fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000c9ffffff
ExtTag+ RBE+
Slot #11, PowerLimit 75.000W; Interlock- NoCompl+
Capabilities: [b0] Subsystem: ASRock Incorporation RD890/RD990 PCI to PCI bridge (PCI Express GFX2 port 0)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40) (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32
Interrupt: pin A routed to IRQ 19
NUMA node: 0
Region 0: I/O ports at f090
Region 1: I/O ports at f080
Region 2: I/O ports at f070
Region 3: I/O ports at f060
Region 4: I/O ports at f050
Region 5: Memory at fc10b000 (32-bit, non-prefetchable)
Capabilities: [70] SATA HBA v1.0 InCfgSpace
Capabilities: [a4] PCI Advanced Features
AFCap: TP+ FLR+
AFCtrl: FLR-
AFStatus: TP-
Kernel driver in use: ahci
Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Subsystem: ASRock Incorporation SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 18
NUMA node: 0
Region 0: Memory at fc10a000 (32-bit, non-prefetchable)
Kernel driver in use: ohci-pci
Kernel modules: ohci_pci
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Subsystem: ASRock Incorporation SB7x0/SB8x0/SB9x0 USB EHCI Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin B routed to IRQ 17
NUMA node: 0
Region 0: Memory at fc109000 (32-bit, non-prefetchable)
Capabilities: [c0] Power Management version 2
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Bridge: PM- B3+
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
NUMA node: 0
Region 0: Memory at fc108000 (32-bit, non-prefetchable)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
NUMA node: 0
Region 0: Memory at fc107000 (32-bit, non-prefetchable)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME+
Bridge: PM- B3+
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 42)
Subsystem: ASRock Incorporation SBx00 SMBus Controller
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 IDE Controller (rev 40) (prog-if 8a [Master SecP PriP])
Subsystem: ASRock Incorporation SB7x0/SB8x0/SB9x0 IDE Controller
Latency: 32
NUMA node: 0
Region 0: I/O ports at 01f0
Region 1: I/O ports at 03f4
Region 2: I/O ports at 0170
Region 3: I/O ports at 0374
Region 4: I/O ports at f000
Kernel driver in use: pata_atiixp
Kernel modules: pata_atiixp, ata_generic
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA) (rev 40)
Subsystem: ASRock Incorporation SBx00 Azalia (Intel HDA)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
NUMA node: 0
Region 0: Memory at fc100000 (64-bit, non-prefetchable)
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
Subsystem: ASRock Incorporation SB7x0/SB8x0/SB9x0 LPC host controller
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
NUMA node: 0
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (rev 40) (prog-if 01 [Subtractive decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop+ ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 64
NUMA node: 0
Bus: primary=00, secondary=06, subordinate=06, sec-latency=64
Memory behind bridge: fff00000-000fffff
Prefetchable memory behind bridge: fff00000-000fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller (prog-if 10 [OHCI])
Subsystem: ASRock Incorporation SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
Interrupt: pin C routed to IRQ 18
NUMA node: 0
Region 0: Memory at fc106000 (32-bit, non-prefetchable)
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
Memory behind bridge: fe200000-fe3fffff
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [58] Express (v2) Root Port (Slot-), MSI 00
ExtTag+ RBE+
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0)
00:16.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
NUMA node: 0
Region 0: Memory at fc105000 (32-bit, non-prefetchable)
00:16.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
NUMA node: 0
Region 0: Memory at fc104000 (32-bit, non-prefetchable)
Bridge: PM- B3+
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 0
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
NUMA node: 0
Capabilities: [80] HyperTransport: Host or Secondary Interface
Command: WarmRst+ DblEnd- DevNum=0 ChainSide- HostHide+ Slave- <EOCErr- DUL-
Link Control: CFlE- CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn+ ExtCTL- 64b+
Link Config: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=16bit DwFcInEn- LWO=16bit DwFcOutEn-
Revision ID: 3.00
Link Frequency: [b]
Link Error: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability: 200MHz+ 300MHz- 400MHz+ 500MHz- 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz+ 1.4GHz- 1.6GHz- Vend-
Feature Capability: IsocFC+ LDTSTOP+ CRCTM- ECTLT- 64bA+ UIDRD- ExtRS- UCnfE-
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 1
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 2
NUMA node: 0
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 3
NUMA node: 0
Capabilities: [f0] Secure device <?>
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 4
NUMA node: 0
Kernel driver in use: fam15h_power
Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 5
NUMA node: 0
01:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 770] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] GK104 [GeForce GTX 770]
Latency: 0
Interrupt: pin A routed to IRQ 43
NUMA node: 0
Region 0: Memory at fd000000 (32-bit, non-prefetchable)
Region 1: Memory at d0000000 (64-bit, prefetchable)
Region 3: Memory at d8000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
[virtual] Expansion ROM at 000c0000 [disabled]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000feeff00c Data: 41c3
Capabilities: [78] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
LnkCap: Port #0, Speed 5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GK104 HDMI Audio Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GK104 HDMI Audio Controller
Interrupt: pin B routed to IRQ 38
NUMA node: 0
Region 0: Memory at fe080000 (32-bit, non-prefetchable)
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
02:00.0 Non-Volatile memory controller: Device 1987:5007 (rev 01) (prog-if 02 [NVM Express])
Subsystem: Device 1987:5007
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 27
NUMA node: 0
Region 0: Memory at fe600000 (64-bit, non-prefetchable)
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75.000W
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
LnkSta: Speed 5GT/s, Width x2, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [158 v1] Power Budgeting <?>
Capabilities: [168 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [178 v1] #19
Capabilities: [198 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [1a0 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=200us PortTPowerOnTime=200us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=0us
Kernel driver in use: nvme
Kernel modules: nvme
03:00.0 USB controller: Etron Technology, Inc. EJ188/EJ198 USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation EJ188/EJ198 USB 3.0 Host Controller
Interrupt: pin A routed to IRQ 31
NUMA node: 0
Region 0: Memory at fe500000 (64-bit, non-prefetchable)
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [70] MSI: Enable+ Count=1/4 Maskable+ 64bit+
Address: 00000000feeff00c Data: 4192
Masking: 0000000e Pending: 00000000
Capabilities: [a0] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 1024 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
AERCap: First Error Pointer: 14, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [190 v1] Device Serial Number 01-01-01-01-01-01-01-01
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
04:00.0 Ethernet controller: Qualcomm Atheros Killer E220x Gigabit Ethernet Controller (rev 10)
Subsystem: ASRock Incorporation Killer E220x Gigabit Ethernet Controller
Interrupt: pin A routed to IRQ 42
NUMA node: 0
Region 0: Memory at fe400000 (64-bit, non-prefetchable)
Region 2: I/O ports at d000
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [58] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 4096 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn+ AttnInd+ PwrInd+ RBE+ FLReset- SlotPowerLimit 75.000W
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [c0] MSI: Enable+ Count=1/16 Maskable+ 64bit+
Address: 00000000feeff00c Data: 41b3
Masking: 0000fffe Pending: 00000000
Capabilities: [d8] MSI-X: Enable- Count=16 Masked-
UESvrt: DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
Capabilities: [180 v1] Device Serial Number ff-9d-98-dd-d0-50-99-ff
Kernel driver in use: alx
Kernel modules: alx
05:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 770] (rev a1) (prog-if 00 [VGA controller])
Latency: 0
Interrupt: pin A routed to IRQ 44
NUMA node: 0
Region 0: Memory at fb000000 (32-bit, non-prefetchable)
Region 1: Memory at c0000000 (64-bit, prefetchable)
Region 3: Memory at c8000000 (64-bit, prefetchable)
Region 5: I/O ports at c000
[virtual] Expansion ROM at fc000000 [disabled]
Address: 00000000feeff00c Data: 41d3
Status: InProgress-
05:00.1 Audio device: NVIDIA Corporation GK104 HDMI Audio Controller (rev a1)
Interrupt: pin B routed to IRQ 39
NUMA node: 0
Region 0: Memory at fc080000 (32-bit, non-prefetchable)
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk-
07:00.0 Multimedia video controller: Conexant S
