Dear shigeharu.shibahata,
I suspect it is a HW issue. Could you please file a bug with all information and share bug ID via Private message to me to follow it up. Please login to https://developer.nvidia.com/drive with your credentials. Please check MyAccount->MyBugs->Submit a new bug to file bug
Hello shigeharu,
If you have a hmdi cable plugged to AGX:
please shutdown your AGX completely, unplug the HDMI cable. Wait for like more than 60 seconds. The problem will most probably be solved.
Did the solution given by csari3 helped? Can you check dsmeg log for " devinit status verification failed:" error
Dear csari3,
Thank you for your advice!
It works very well for me!
Dear SivaRamaKrishna,
Sorry, I have forgotten to input dmesg command.
First, I tried it and found “devinit status verification failed:” error.
Then I did the way as csari3 said and dmesg does not output that error.
Should I share the bug information via Private message?
Thank you.
Shigeharu
Hello shigeru,
I am glad that i worked well. It is the bug that I found and I have opened a bug
Report for this issue. I think it is a hw bug. It is sort of mentioned in the errata sheet
Thank you Csari3 for providing inputs.
Csari3 is referring to HW errata #8 in https://developer.download.nvidia.com/driveworks/secure/docs/DRIVE_8.0_Release_Docs/DE-08933-001_v07.pdf?VlEbwEzut1rAEF6tZXO3Xt9p9ZYope0E9i6ggvGb7fLqQ6wk0aQiYePQlydacEDtpHQZQ9ZYbvhNUdFWVkSKwYU4T9UwDQzqUGOdrtipK_Cff5xXUc1VB5KA-T53K4xCbysNIUOepcbiYG9mr9O4mUfHc_8L1Hf3Xf5KkW13u0gG
dump your firmware and compare it with uploaded
