Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Current situation :
I connect the Pegasus per Ethernet like this, and the light of the device is also in the following image
I connect the host and target pegasus per
./tcu_muxer tcu_muxer -g 11 tcu_muxer -b 10 -d /dev/ttyUSB2
sudo minicom -D /dev/pts/7
if I execute
ping www.baidu.com
the result is
ping 8.8.8.8
dmesg | grep -i eth
I could make sure the ethernet is OK , even though this is one device could convert WIFI into ethernet signals , when I connect this ethernet with my laptop , it could provide internet signals .
Could you please kindly help me , how to resolve this problem , and could let my pegasus connect with the internet
Dear @yang.liu1,
Could you also share which port it is connected on the target?
Dear @yang.liu1,
In my experience there is no need to make any changes to enable internet. We get eth0 IP from the DCHP server. I have connected to 3/4 port using dual gbe dongle. Could you check if chaging port or restarting target/networking service help?
- Restart does not helpful
- change the port from 1/2 to 3/4 does not helpful also
- How to restart networking service
I want to connect the network per Guest VM 0, is this the reason why I could not get access the internet ?
Dear @yang.liu1,
You can use sudo minicom -D /dev/ttyUSB2
to connect to tegra A terminal. Could you check sudo service systemd-networkd status
also date
From one blog said
from this pic , it said I need to update the default username and password :
see :
https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/Board/board_e3550.html#wwconnect_header
But I could not see any operation env like this :
Does this means I need to reflash the pegasus again ?
If this is the reason , how could I operate immediately after I flash the pegasus ?
Dear @yang.liu1,
I am assuming, you have not changed any files after recent re-flash. Enabling network has nothing to do with default password change. Looks like system date is different. Could you check date
as asked earlier?
We notice for a customer changing date helped to fix internet issues (Connecting AGX to network - #8 by pola5392)
