• Hardware Platform Jetson
• Docker Image deepstream-l4t:6.1-samples
• Issue Type: questions and errors
Hey,
I tried to run a people counting pipeline with deepstream python, but It crashes with the following output:
root@pf90-xavier-nx-01:/ai_vision_mounted# ./start.sh
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 204)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
(gst-plugin-scanner:189): GStreamer-WARNING **: 15:15:54.463: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:189): GStreamer-WARNING **: 15:15:54.731: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
Creating Pipeline
Creating streamux
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
Creating source_bin 0
Creating source bin
source-bin-00
Creating source_bin 1
Creating source bin
source-bin-01
Creating Pgie
WARNING: Overriding infer-config batch-size 1 with number of sources 2
Creating tiler
Creating nvvidconv
Creating nvosd
Pipeline graph logged under /ai_vision/pipeline_graphs/RtspToDisplayPipeline
Starting pipeline
Using winsys: x11
0:00:03.353452876 188 0x394bd300 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:03.355208445 188 0x394bd300 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
0:01:17.038852445 188 0x394bd300 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1946> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b2_gpu0_int8.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:17.141364179 188 0x394bd300 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:configs/dstest1_pgie_config.txt sucessfully
Decodebin child added: source
Warning: gst-resource-error-quark: Could not read from resource. (9): gstrtspsrc.c(5769): gst_rtspsrc_reconnect (): /GstPipeline:pipeline0/GstBin:source-bin-01/GstURIDecodeBin:uri-decode-bin/GstRTSPSrc:source:
Could not receive any UDP packets for 5.0000 seconds, maybe your firewall is blocking it. Retrying using a tcp connection.
Warning: gst-resource-error-quark: Could not read from resource. (9): gstrtspsrc.c(5769): gst_rtspsrc_reconnect (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin/GstRTSPSrc:source:
Decodebin child added: decodebin0
Decodebin child added: decodebin1
Decodebin child added: rtph264depay0
Decodebin child added: rtph264depay1
Decodebin child added: h264parse0
Decodebin child added: h264parse1
Decodebin child added: capsfilter0
Decodebin child added: capsfilter1
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder1
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In _cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0xffffa228c580 (GstCapsFeatures at 0xfffec00aaf00)>
In _cb_newpad
features= <Gst.CapsFeatures object at 0xffffa228c6a0 (GstCapsFeatures at 0xfffebc078ae0)>
[Error while parsing streammux config file: Key file does not have key “enable-source-rate-control” in group “property”]
max_fps_dur 1.25e+08 min_fps_dur 1e+09
reference in DPB was never decoded
NVDEC_COMMON: NvDecGetSurfPinHandle : Surface not registered
0:01:23.483132076 188 0x38b69e40 WARN nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:01:23.483213261 188 0x38b69e40 WARN nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason error (-5)
Error: gst-stream-error-quark: Internal data stream error. (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2299): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
[ERROR push 334] push failed [-2]
The created pipeline looks like this:
There are the following errors found when running the pipeline with GST_DEBUG=4:
0:01:26.503431992 57 0xfffed8004060 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<nvvideo-renderer> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:01:26.505241757 57 0xfffed8004000 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)8/1, batch-size=(int)2, num-surfaces-per-frame=(int)1
0:01:26.506362177 57 0xfffed8004000 INFO basetransform gstbasetransform.c:1317:gst_base_transform_setcaps:<primary-inference> reuse caps
0:01:26.506520033 57 0xfffed8004000 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)8/1, batch-size=(int)2, num-surfaces-per-frame=(int)1
0:01:26.506878498 57 0xfffed8004000 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)8/1, batch-size=(int)1, num-surfaces-per-frame=(int)1
0:01:26.510505550 57 0xfffed8004000 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)8/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA, block-linear=(boolean)false
0:01:26.510836303 57 0xfffed8004000 INFO basetransform gstbasetransform.c:1317:gst_base_transform_setcaps:<onscreendisplay> reuse caps
0:01:26.512475764 57 0xfffed8004000 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)8/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA, block-linear=(boolean)false
0:01:26.512862901 57 0xfffed8004000 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw(memory:EGLImage), width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)8/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA, block-linear=(boolean)false
0:01:26.513509111 57 0x3a77a1e0 ERROR egladaption gstegladaptation.c:660:gst_egl_adaptation_choose_config:<nvvideo-renderer> Could not find matching framebuffer config
0:01:26.513569143 57 0x3a77a1e0 ERROR egladaption gstegladaptation.c:674:gst_egl_adaptation_choose_config:<nvvideo-renderer> Couldn't choose an usable config
0:01:26.513597719 57 0x3a77a1e0 ERROR nveglglessink gsteglglessink.c:2709:gst_eglglessink_configure_caps:<nvvideo-renderer> Couldn't choose EGL config
0:01:26.513621751 57 0x3a77a1e0 ERROR nveglglessink gsteglglessink.c:2767:gst_eglglessink_configure_caps:<nvvideo-renderer> Configuring caps failed
0:01:26.513688855 57 0xfffed8004000 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.513953368 57 0xfffed8004000 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.514397337 57 0xfffed8004000 WARN GST_PADS gstpad.c:4231:gst_pad_peer_query:<nvegl-transform:src> could not send sticky events
0:01:26.520872333 57 0xfffed8004000 INFO task gsttask.c:460:gst_task_set_lock: setting stream lock 0x3a770120 on task 0xfffeb0065950
0:01:26.520963118 57 0xfffed8004000 INFO GST_PADS gstpad.c:6159:gst_pad_start_task:<Stream-muxer:src> created task 0xfffeb0065950
0:01:26.521526447 57 0xfffed8004000 INFO v4l2 gstv4l2object.c:3173:gst_v4l2_object_setup_pool:<nvv4l2decoder1:src> accessing buffers via mode 2
0:01:26.521535631 57 0xfffee4033060 INFO GST_EVENT gstevent.c:900:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:01:26.521734768 57 0xfffed8004060 INFO v4l2 gstv4l2object.c:3173:gst_v4l2_object_setup_pool:<nvv4l2decoder0:src> accessing buffers via mode 2
0:01:26.522127921 57 0xfffee4033060 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.522224914 57 0xfffed8004060 INFO v4l2bufferpool gstv4l2bufferpool.c:801:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder0:pool:src> increasing minimum buffers to 2
0:01:26.522151089 57 0xfffed8004000 INFO v4l2bufferpool gstv4l2bufferpool.c:801:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder1:pool:src> increasing minimum buffers to 2
0:01:26.522342866 57 0xfffed8004060 INFO v4l2bufferpool gstv4l2bufferpool.c:808:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder0:pool:src> increasing minimum buffers to 6
0:01:26.522692755 57 0xfffed8004000 INFO v4l2bufferpool gstv4l2bufferpool.c:808:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder1:pool:src> increasing minimum buffers to 6
0:01:26.522913716 57 0xfffed8004000 INFO v4l2bufferpool gstv4l2bufferpool.c:815:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder1:pool:src> reducing maximum buffers to 64
0:01:26.522965780 57 0xfffed8004000 INFO v4l2bufferpool gstv4l2bufferpool.c:838:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder1:pool:src> adding needed video meta
0:01:26.522762643 57 0xfffed8004060 INFO v4l2bufferpool gstv4l2bufferpool.c:815:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder0:pool:src> reducing maximum buffers to 64
0:01:26.523026612 57 0xfffed8004060 INFO v4l2bufferpool gstv4l2bufferpool.c:838:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder0:pool:src> adding needed video meta
0:01:26.523139540 57 0xfffed8004000 INFO v4l2bufferpool gstv4l2bufferpool.c:815:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder1:pool:src> reducing maximum buffers to 64
0:01:26.523172692 57 0xfffed8004060 INFO v4l2bufferpool gstv4l2bufferpool.c:815:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder0:pool:src> reducing maximum buffers to 64
0:01:26.523380117 57 0xfffed8004060 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:01:26.523813142 57 0xfffed8004000 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder1> Duration invalid, not setting latency
0:01:26.524016247 57 0xfffed8004060 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:26.524365304 57 0xfffed8004060 INFO task gsttask.c:460:gst_task_set_lock: setting stream lock 0xfffeb0020a50 on task 0xfffee4066ef0
0:01:26.524413400 57 0xfffed8004060 INFO GST_PADS gstpad.c:6159:gst_pad_start_task:<nvv4l2decoder0:src> created task 0xfffee4066ef0
0:01:26.525061146 57 0xfffed8004000 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:<nvv4l2decoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:26.525702012 57 0xfffed8004000 INFO task gsttask.c:460:gst_task_set_lock: setting stream lock 0xfffebc05f680 on task 0xfffee405da70
0:01:26.525814141 57 0xfffed8004000 INFO GST_PADS gstpad.c:6159:gst_pad_start_task:<nvv4l2decoder1:src> created task 0xfffee405da70
0:01:26.527279905 57 0xfffed8004000 INFO basetransform gstbasetransform.c:1317:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:01:26.527454914 57 0xfffed8004000 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder1:pool:sink> Buffer 0xfffea8009c60 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.527688066 57 0xfffed8004000 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder1:pool:sink> Buffer 0xfffee405d120 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.527971523 57 0xfffed8004000 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder1:pool:sink> Buffer 0xfffee4063120 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.528136260 57 0xfffed8004000 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder1:pool:sink> Buffer 0xfffee4066000 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.528518501 57 0xfffed8004060 INFO basetransform gstbasetransform.c:1317:gst_base_transform_setcaps:<capsfilter1> reuse caps
0:01:26.528721734 57 0xfffed8004060 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder0:pool:sink> Buffer 0xfffec0006ea0 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.528971238 57 0xfffed8004060 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder0:pool:sink> Buffer 0xfffed802f240 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.529121287 57 0xfffed8004060 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder0:pool:sink> Buffer 0xfffed802f000 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.529679209 57 0xfffed8004060 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder0:pool:sink> Buffer 0xfffed80356c0 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.530493163 57 0xfffeb0015120 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:26.531394894 57 0xfffebc012d80 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder1:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:26.531419502 57 0xfffeb0015120 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.531711951 57 0xfffeb0015120 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.531795983 57 0xfffeb0015120 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.531974480 57 0xfffeb0015120 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.532054512 57 0xfffeb0015120 INFO videodecoder gstvideodecoder.c:3184:gst_video_decoder_clip_and_push_buf:<nvv4l2decoder0> First buffer since flush took 0:00:00.145823713 to produce
0:01:26.532771826 57 0xfffebc012d80 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.532943411 57 0xfffebc012d80 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.533053363 57 0xfffebc012d80 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.533479220 57 0xfffebc012d80 ERROR nveglglessink gsteglglessink.c:2808:gst_eglglessink_setcaps:<nvvideo-renderer> Failed to configure caps
0:01:26.533579797 57 0xfffebc012d80 INFO videodecoder gstvideodecoder.c:3184:gst_video_decoder_clip_and_push_buf:<nvv4l2decoder1> First buffer since flush took 0:00:00.148782153 to produce
0:01:26.720819637 57 0xfffed8004060 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder0:pool:sink> Buffer 0xfffed8035360 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.720818261 57 0xfffed8004000 WARN bufferpool gstbufferpool.c:1235:default_reset_buffer:<nvv4l2decoder1:pool:sink> Buffer 0xfffea8009ea0 without the memory tag has maxsize (0) that is smaller than the configured buffer pool size (4194304). The buffer will be not be reused. This is most likely a bug in this GstBufferPool subclass
0:01:26.797108287 57 0x3a77a240 ERROR nvegltransform gstnvegltransform.c:419:gst_nvegl_transform_transform:<nvegl-transform> Something is wrong, EGLImage is expected.
0:01:26.797386752 57 0x3a77a240 WARN nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:01:26.797474304 57 0x3a77a240 WARN nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason error (-5)
0:01:26.797559905 57 0x3a77a240 INFO GST_ERROR_SYSTEM gstelement.c:2153:gst_element_message_full_with_details:<primary-inference> posting message: Internal data stream error.
0:01:26.797873186 57 0x3a77a240 INFO GST_ERROR_SYSTEM gstelement.c:2180:gst_element_message_full_with_details:<primary-inference> posted error message: Internal data stream error.
I connected to the jetson via ssh and after that the docker container is started with --net=host. There is also a monitor connected to the Jetson via HDMI. The connection to the RTSP source is working fine, so that the following pipeline can display the stream on the Jetson display:
gst-launch-1.0 uridecodebin uri=rtsp://172.17.15.148:9000/live ! nvvidconv ! autovideosink
Could someone explain the error messages from the logs to help me fix the problem?
I can provide the python code if necessary.
