• Hardware (T4/V100/Xavier/Nano/etc): GTX 1060
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc): PeopleNet
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here): 8.2.5
• Training spec file(If have, please share here): none
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.): read on
I tried to use the PeopleNet 2.3 or newer to detect persons, bags and faces. It detects persons and faces just fine but it doesn’t detect a single bag, not even in the showcase in the NGC page. PeopleNet 2.0 based on ResNet18 does detect bags but it’s not as accurate as ResNet34 in the other two classes.
I tried the models pruned_quantized_v2.3 and deployable_quantized_v2.6. I converted them to trt using this command:
./tao-converter resnet34_peoplenet_pruned_int8.etlt -d 3,768,1024 -k tlt_encode -o output_cov/Sigmoid,output_bbox/BiasAdd -i nchw -m 1 -t int8 -e trt_model.trt -s
This is the output of this command:
[INFO] [MemUsageChange] Init CUDA: CPU +193, GPU +0, now: CPU 204, GPU 862 (MiB)
[INFO] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 204 MiB, GPU 862 MiB
[INFO] [MemUsageSnapshot] End constructing builder kernel library: CPU 268 MiB, GPU 862 MiB
[WARNING] TensorRT was linked against cuBLAS/cuBLASLt 11.6.5 but loaded cuBLAS/cuBLASLt 11.6.1
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +248, GPU +102, now: CPU 536, GPU 964 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +149, GPU +108, now: CPU 685, GPU 1072 (MiB)
[INFO] Timing cache disabled. Turning it on will improve builder speed.
[INFO] Detected 1 inputs and 2 output network tensors.
[INFO] Total Host Persistent Memory: 10336
[INFO] Total Device Persistent Memory: 0
[INFO] Total Scratch Memory: 0
[INFO] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 0 MiB, GPU 410 MiB
[INFO] [BlockAssignment] Algorithm ShiftNTopDown took 35.7075ms to assign 4 blocks to 248 nodes requiring 515899392 bytes.
[INFO] Total Activation Memory: 515899392
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 876, GPU 1154 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 876, GPU 1162 (MiB)
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +10, now: CPU 875, GPU 1138 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +1, GPU +8, now: CPU 876, GPU 1146 (MiB)
[INFO] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +492, now: CPU 0, GPU 501 (MiB)
[INFO] Starting Calibration with batch size 8.
[INFO] Post Processing Calibration data in 6.02e-07 seconds.
[INFO] Calibration completed in 3.1918 seconds.
[INFO] Writing Calibration Cache for calibrator: TRT-8205-EntropyCalibration2
[WARNING] Missing scale and zero-point for tensor output_bbox/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor input_1, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor conv1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor conv1/convolution, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor conv1/bias, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor conv1/BiasAdd, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/moving_variance, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/Reshape_1/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/batchnorm/add/y, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/gamma, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/Reshape_3/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/batchnorm/mul_1, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/beta, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/Reshape_2/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/moving_mean, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/Reshape/shape, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor bn_conv1/batchnorm/add_1, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor block_1a_conv_1/kernel, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor block_1a_conv_1/convolution, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
... (snipped due to size limit)
[WARNING] Missing scale and zero-point for tensor output_cov/BiasAdd, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing scale and zero-point for tensor output_cov/Sigmoid, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +10, now: CPU 878, GPU 1138 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 878, GPU 1146 (MiB)
[INFO] Local timing cache in use. Profiling results in this builder pass will not be stored.
[INFO] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[INFO] Total Host Persistent Memory: 103584
[INFO] Total Device Persistent Memory: 7409664
[INFO] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 10 MiB, GPU 1010 MiB
[INFO] [BlockAssignment] Algorithm ShiftNTopDown took 2.21526ms to assign 4 blocks to 67 nodes requiring 38830080 bytes.
[INFO] Total Activation Memory: 38830080
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 881, GPU 1152 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 881, GPU 1160 (MiB)
[INFO] [MemUsageChange] TensorRT-managed allocation in building engine: CPU +2, GPU +8, now: CPU 2, GPU 8 (MiB)
For inference, I took the example for detectnet_v2 and I just changed the path to the trt file. The example has three classes also, they are named differently but it shouldn’t matter. And I didn’t notice any bag being detected except the case when I tried the ResNet18 model.
I also tried the example code at https://forums.developer.nvidia.com/t/run-peoplenet-with-tensorrt/128000/20. The same thing happens there. Bags are detected only in the ResNet18 model.
