Ok, pls try following command before you run the test:
- Max power mode is enabled:
$ sudo nvpmodel -m 0
- The GPU clocks are stepped to maximum:
$ sudo jetson_clocks
Also what is your pipeline and can you refer DeepStream SDK FAQ - #11 by bcao to find which element is the bottleneck. And I think it is better to profile the model’s perf using trtexec .
