people already moved , but the transform never change, how can it change
Does the people_control can’t change the transformation, only a animation???
Check the prims underneath, the SkelRoot should have the updated transform. Also look at this thread:
Thank you for your answer,
I tried to use TF_publisher to get transform information, and it works
the transform information from the UI still zero, But this doesn’t matter
most importantly, I set the semantics for this person, and the bbox3d is correct, even precise in rendering, But the size is wrong, no one is 0.48m tall
Do you have any experience or solutions in this regard
Your help is greatly appreciated
is there any body can help me, please
