• Hardware Platform: Jetson Xavier NX 8GB
• DeepStream Version: 6.2
• JetPack Version: 5.1.1
• TensorRT Version: 8.5.2.2
• Issue Type: Performace
Hi, I’m using the resnet34_peoplenet_int8 in a simple python pipeline with two cameras. I noticed (using jtop) that my GPU is pretty much getting maxed out with only two cameras - what can be causing this - bellow is my pipeline and config…
Thanks in advance :)
Config…
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=Models/PeopleNet/resnet34_peoplenet_int8.etlt
labelfile-path=Models/PeopleNet/labels_peoplenet.txt
model-engine-file=Models/PeopleNet/resnet34_peoplenet_int8.etlt_b2_gpu0_int8.engine
int8-calib-file=Models/PeopleNet/resnet34_peoplenet_int8.txt
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=2
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=3
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[class-attrs-all]
pre-cluster-threshold=0.4
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
# disable bag detection
[class-attrs-1]
pre-cluster-threshold=1.0
# disable face detection
[class-attrs-2]
[class-attrs-all]
pre-cluster-threshold=0.5
topk=20
nms-iou-threshold=0.5
Python code…
import queue
import sys
import math
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
from gi.repository import GLib
from nvidia_source_functions import create_source_bin
from ctypes import *
from bindings.build import pyds
OUTPUT_WIDTH = 1280
OUTPUT_HEIGHT = 720
STREAM_0 = 'rtsp://username:password@192.168.88.207:554/cam/realmonitor?channel=1&subtype=0'
STREAM_1 = 'rtsp://username:password@192.168.88.208:554/cam/realmonitor?channel=1&subtype=0'
def createNewPipeline():
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
return pipeline
def createStreamMux(number_sources):
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
streammux.set_property('live-source', 1)
streammux.set_property('width', 1280)
streammux.set_property('height', 720)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
return streammux
def addSourceToPipelineAndLinkToSteamMux(pipeline,streammux,STREAM,sinkPadName,index):
# add first stream
source_bin = create_source_bin(index, STREAM)
pipeline.add(source_bin)
sinkpad = streammux.get_request_pad(sinkPadName)
srcpad=source_bin.get_static_pad("src")
srcpad.link(sinkpad)
def createNVOSD():
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
nvosd.set_property('process-mode', 0)
nvosd.set_property('display-text', 1)
return nvosd
def createPGIE():
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
pgie.set_property('config-file-path', 'config_infer_primary.txt')
return pgie
def createTiler():
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
tiler_rows = 1 #int(math.sqrt(number_sources))
tiler_columns = 2 #int(math.ceil((1.0*number_sources)/tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", OUTPUT_WIDTH)
tiler.set_property("height", OUTPUT_HEIGHT)
return tiler
def main(args):
number_sources = 2
GObject.threads_init()
Gst.init(None)
pipeline = createNewPipeline()
streammux = createStreamMux(number_sources)
pipeline.add(streammux)
addSourceToPipelineAndLinkToSteamMux(pipeline,streammux,STREAM_0,'sink_0',0)
addSourceToPipelineAndLinkToSteamMux(pipeline,streammux,STREAM_1,'sink_1',1)
queue1 = Gst.ElementFactory.make("queue", "queue1")
queue2 = Gst.ElementFactory.make("queue", "queue2")
queue3 = Gst.ElementFactory.make("queue", "queue3")
queue4 = Gst.ElementFactory.make("queue", "queue4")
queue5 = Gst.ElementFactory.make("queue", "queue5")
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(queue3)
pipeline.add(queue4)
pipeline.add(queue5)
pgie = createPGIE()
tiler = createTiler()
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
nvosd = createNVOSD()
transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
sink.set_property("qos", 0)
pipeline.add(pgie)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(transform)
pipeline.add(sink)
streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tiler)
tiler.link(queue3)
queue3.link(nvvidconv)
nvvidconv.link(queue4)
queue4.link(nvosd)
nvosd.link(queue5)
queue5.link(transform)
transform.link(sink)
loop = GLib.MainLoop()
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
print("Exiting app\n")
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
sys.exit(main(sys.argv))
