I am trying to use perf for profiling on a target Xavier. However, I am receiving the following output:
Performance counter stats for 'CPU(s) 1':
3002.616160 cpu-clock (msec) # 1.000 CPUs utilized
253 context-switches # 0.084 K/sec
33 cpu-migrations # 0.011 K/sec
0 page-faults # 0.000 K/sec
<not supported> cycles
<not supported> instructions
<not supported> branches
<not supported> branch-misses
3.002808256 seconds time elapsed
Many of the interesting values seem not to be supported.What could be going wrong? Are there better ways to monitor those not-supported performances?
Hi xiayu.hua,
We tried below command on r32.6.1/Xavier, only ‘branches’ value show not supported.
$ sudo ./perf stat --cpu 1
425609.471648 cpu-clock (msec) # 1.000 CPUs utilized
59,603 context-switches # 0.140 K/sec
1,732 cpu-migrations # 0.004 K/sec
97,780 page-faults # 0.230 K/sec
56,950,668,198 cycles # 0.134 GHz
82,264,129,748 instructions # 1.44 insn per cycle
346,966,194 branch-misses
425.627736430 seconds time elapsed
Are you using the same command with r32.6.1?
Please try again without using VM. Thanks!
I am more curious about why you have a VM there. Are you installing a VM on jetson AGX?
Thanks for the quick reply. The fact is, I directly ssh to the board and run the perf command, I don’t think it’s in a virtualization environment.
Then why did you say it is a Linux virtual machine in first comment?
Has corrected the description. It’s actually on a target Xavier
