I was trying to measure last level cache miss rate for Xavier’s Carmel CPU.
The Carmel CPU in Xavier has 3 levels of cache.
But when I use the perf list, it only shows the first level cache. How can I measure the last level cache miss rate? I would really appreciate any help regarding this.
There is one hardware event named cache-misses which is lower than the number L1 cache misses. So I am not sure what that value represents.
For example, below is the perf output for available cache related counters.
sudo perf list |grep cache
cache-misses [Hardware event]
cache-references [Hardware event]
L1-dcache-load-misses [Hardware cache event]
L1-dcache-loads [Hardware cache event]
L1-dcache-store-misses [Hardware cache event]
L1-dcache-stores [Hardware cache event]
L1-icache-load-misses [Hardware cache event]
L1-icache-loads [Hardware cache event]
branch-load-misses [Hardware cache event]
branch-loads [Hardware cache event]
dTLB-load-misses [Hardware cache event]
iTLB-load-misses [Hardware cache event]
armv8_pmuv3/l1d_cache/ [Kernel PMU event]
armv8_pmuv3/l1d_cache_refill/ [Kernel PMU event]
armv8_pmuv3/l1d_cache_wb/ [Kernel PMU event]
armv8_pmuv3/l1i_cache/ [Kernel PMU event]
armv8_pmuv3/l1i_cache_refill/ [Kernel PMU event]
ext4:ext4_es_cache_extent [Tracepoint event]
ext4:ext4_ext_in_cache [Tracepoint event]
ext4:ext4_ext_put_in_cache [Tracepoint event]
filemap:mm_filemap_add_to_page_cache [Tracepoint event]
filemap:mm_filemap_delete_from_page_cache [Tracepoint event]
kmem:kmem_cache_alloc [Tracepoint event]
kmem:kmem_cache_alloc_node [Tracepoint event]
kmem:kmem_cache_free [Tracepoint event]
nvmap:nvmap_cache_flush [Tracepoint event]
nvmap:nvmap_cache_maint [Tracepoint event]
nvmap:pp_clean_cache [Tracepoint event]
regmap:regcache_drop_region [Tracepoint event]
regmap:regcache_sync [Tracepoint event]
regmap:regmap_cache_bypass [Tracepoint event]
regmap:regmap_cache_only [Tracepoint event]
regmap:regmap_reg_read_cache [Tracepoint event]
