Hardware Environment:
- System: NVIDIA DGX Grace-Blackwell (GB10)
- CPU: NVIDIA Grace (ARM64)
- GPU: 1x Blackwell GB10 (128GB VRAM)
- Interconnect: NVLink-C2C (900GB/s)
The Issue:
We are deploying an internal Agentic RAG system using Qwen2.5-Coder-32B-Instruct via vLLM. In our initial testing, we encountered a throughput of only 3.7 tokens/second, which is significantly below the expected TFLOPS for this architecture.
Our Findings:
- Instruction Set Mismatch: We discovered that standard Docker Hub images for vllm-openai are defaulting to x86_64, triggering QEMU emulation on the Grace CPU. This appears to be “starving” the GPU due to translation overhead.
- Library Linking (CUDA 13): On the nvcr.io/nvidia/pytorch:25.01-py3 base, installing vLLM via pip leads to ImportError: libcudart.so.13 not found. We found that the runtime is installed in a nested Python directory and not in the system’s standard /usr/lib or /usr/local/cuda/lib64.
- Dependency Conflicts: Bare pip install vllm uninstalls the NVIDIA-optimized +nv PyTorch, replacing it with a generic build that lacks the Blackwell (SM 10.0) math kernels.
The Question for the Community:
- Is there an official, pre-integrated Native ARM64 vLLM image on NGC that is specifically tuned for the Blackwell SM 10.0 instruction set and the Grace-ARM architecture?
- What is the recommended best practice for linking CUDA 13.0 runtime libraries within a containerized environment to avoid manual symlinking of libcudart.so.13?
- Are there specific FlashInfer or TransformerEngine environment flags recommended for maximizing the Grace-to-Blackwell NVLink-C2C bandwidth during the decode phase of inference?
