After converting a YOLO ( classifcation) model from ONNX to DeepStream format, I noticed that the model’s performance decreased significantly, from an F1 score of 98% to 67%!
Why is this happening, and is there a method to correct the situation?
When converting to DeepStream, how do you run the evaluation, and are the preprocessing steps between DeepStream and when you run PyTorch the same?
• DeepStream Version
• TensorRT Version
One reason this may occur is due to Ultralytics using a padding with (114,114,114), while DeepStream uses (0,0,0).
Thank you very much for your response @Y-T-G . I appreciate your insight on the padding issue.
To resolve this problem and make the padding compatible between DeepStream and Ultralytics, do you suggest a specific approach or configuration to modify the padding values? Should I adjust the model preprocessing steps to ensure consistency, or would you recommend another solution?
Looking forward to your guidance.
Best regards
Thank you very much for your response @lqdisme. When I convert the model to DeepStream, I evaluate the performance by testing the model on the same test data (images) used to test the PyTorch model. I use the model generated with DeepStream and test this model with TensorRT.
I don’t think DeepStream supports padding with different color. The alternative is to modify Ultralytics to pad with 0,0,0
do you mean the TRT engine generated with DeepStream is used in PyTorch test?
please refer to this faq for “Debug Tips for DeepStream Accuracy Issue”.
