Performance issue getting CUeglFrame from EGLImageKHR
I developed a gstreamer plugin by modifying nvcompositor to process and combine two images.
I mostly modified the code in function do_nvcomposite to replace the call to NvBufferComposite with my own CUDA processing. To do so, inspired by this post, I call, for my 3 images (2 inputs and 1 output):
  • NvEGLImageFromFd to retrieve EGLImageKHR instances
  • then cuGraphicsEGLRegisterImage
  • then cuGraphicsResourceGetMappedEglFrame to get a CUeglFrame instance
  • (apply CUDA processing to combine the 2 inputs into the output)
  • cuGraphicsUnregisterResource
  • then NvDestroyEGLImage
While I try to optimize my CUDA kernels to reduce the processing time, I realize that the only calls to cuGraphicsEGLRegisterImage, cuGraphicsResourceGetMappedEglFrameand cuGraphicsUnregisterResource take 6 to 8 milliseconds per frame (for 3 images), which seems a lot.
Is this something expected, or is there something I should do differently?
In case it helps, here is a typical pipeline to reproduce:
gst-launch-1.0 -e  \
filesrc location=$path1  ! qtdemux ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw\(memory:NVMM\),format=RGBA,width=3024,height=2280 ! mix. \
filesrc location=$path2 ! qtdemux ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw\(memory:NVMM\),format=RGBA,width=3024,height=2280 ! mix. \
my_plugin name=mix ! \
video/x-raw\(memory:NVMM\),format=RGBA,width=6048,height=2280 ! \
fakesink
and a few code extracts:
static gboolean
do_nvcomposite (GstVideoAggregator * vagg, gint out_dmabuf_fd)
	// Beginning unchanged
	EGLImageKHR image1 = NvEGLImageFromFd(egl_display, input_dmabuf_fds[0]);
	if (image1 == EGL_NO_IMAGE_KHR)
		GST_ERROR("NvEGLImageFromFd failed for image 1");
		return FALSE;
	EGLImageKHR image2 = NvEGLImageFromFd(egl_display, input_dmabuf_fds[1]);
	if (image2 == EGL_NO_IMAGE_KHR)
		GST_ERROR("NvEGLImageFromFd failed for image 2");
		return FALSE;
	EGLImageKHR out_image = NvEGLImageFromFd(egl_display, out_dmabuf_fd);
	if (out_image == EGL_NO_IMAGE_KHR)
		GST_ERROR("NvEGLImageFromFd failed for output image");
		return FALSE;
	// Processing
    if (ProcessFrame(image1, image2, out_image) != CUDA_SUCCESS)
		GST_ERROR("ProcessFrame failed");
	// Release EGL images
	NvDestroyEGLImage(egl_display, image1);
	NvDestroyEGLImage(egl_display, image2);
	NvDestroyEGLImage(egl_display, out_image);
	// end of function unchanged: calls to NvReleaseFd
The method ProcessFrame is in a separate .cu file:
CUresult EGLImageToFrame(EGLImageKHR egl_image, CUgraphicsResource* pResource, CUeglFrame* pegl_frame, CUgraphicsMapResourceFlags mapFlags)
	CUresult cuResult;
	cuResult = cuGraphicsEGLRegisterImage(pResource, egl_image, mapFlags);
	if (cuResult != CUDA_SUCCESS) {
		HandleError(cuResult, __FILE__, __LINE__, false);
		return cuResult;
	cuResult = HANDLE_ERROR_NO_ABORT(cuGraphicsResourceGetMappedEglFrame(pegl_frame, *pResource, 0, 0));
		Log::Error("cuGraphicsResourceGetMappedEglFrame failed.");
		return cuResult;
	return cuResult;
static bool initialized = false;
DATSTITCH_EXPORT CUresult ProcessFrame(EGLImageKHR image1, EGLImageKHR image2, EGLImageKHR out_image)
	auto start = std::chrono::high_resolution_clock::now();
	CUresult res;
	// Get EGL frames from EGLImageKHR images
	cudaFree(0); // Required to use CUDA context in this thread
	CUeglFrame eglFrame1, eglFrame2, eglFrameOut;
	CUgraphicsResource pResource1 = NULL, pResource2 = NULL, pResourceOut = NULL;
	if ((res = EGLImageToFrame(image1, &pResource1, &eglFrame1, CU_GRAPHICS_MAP_RESOURCE_FLAGS_READ_ONLY)) != CUDA_SUCCESS)
		Log::Error("EGLImageToFrame failed for image 1");
		return res;
	if ((res = EGLImageToFrame(image2, &pResource2, &eglFrame2, CU_GRAPHICS_MAP_RESOURCE_FLAGS_READ_ONLY)) != CUDA_SUCCESS)
		Log::Error("EGLImageToFrame failed for image 2");
		return res;
	if ((res = EGLImageToFrame(out_image, &pResourceOut, &eglFrameOut, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE)) != CUDA_SUCCESS)
		Log::Error("EGLImageToFrame failed for output image");
		return res;
	CUresult cuResult = HANDLE_ERROR_NO_ABORT(cuCtxSynchronize());
		Log::Error("cuCtxSynchronize failed.");
		return cuResult;
	// Initialize if necessary
	if (!initialized)
		// Complete initialization here
		initialized = true;
	// Process the frame
	if (eglFrame1.frameType == CU_EGL_FRAME_TYPE_PITCH &&
		eglFrame2.frameType == CU_EGL_FRAME_TYPE_PITCH &&
		eglFrameOut.frameType == CU_EGL_FRAME_TYPE_PITCH)
		if (eglFrame1.eglColorFormat == CU_EGL_COLOR_FORMAT_ABGR &&
			eglFrame2.eglColorFormat == CU_EGL_COLOR_FORMAT_ABGR &&
			eglFrameOut.eglColorFormat == CU_EGL_COLOR_FORMAT_ABGR)
			/* Apply gpu processing here */
			// Even when the processing code is commented out, I still have a total of 6 to 8 ms spent in the ProcessFrame function
		else
			Log::Error("Invalid eglcolorformat");
	else
		Log::Error("Invalid frame type");
	if (cuCtxSynchronize() != CUDA_SUCCESS)
		Log::Error("cuCtxSynchronize failed");
	if (cuGraphicsUnregisterResource(pResource1) != CUDA_SUCCESS)
		Log::Error("cuGraphicsUnregisterResource for image 1 failed");
	if (cuGraphicsUnregisterResource(pResource2) != CUDA_SUCCESS)
		Log::Error("cuGraphicsUnregisterResource for image 2 failed");
	if (cuGraphicsUnregisterResource(pResourceOut) != CUDA_SUCCESS)
		Log::Error("cuGraphicsUnregisterResource for output image failed");
	auto end = std::chrono::high_resolution_clock::now();
	Log::Debug(STR("ProcessFrame done in " << std::chrono::duration_cast<std::chrono::milliseconds>(end - start).count() << " ms"));
	return CUDA_SUCCESS;
Here is my configuration:
  • Hardware: Jetson Nano Developer Kit, SoC: tegra 210
  • JetPack: 4.6., L4T 32.7.1, Ubuntu 18.04.6 LTS
  • gstreamer version: 1.14.5
The function calls are must-have for synchronizing the data. It is an optimal solution and there may not have room for further enhancement. Please note this.
OK, thanks for the straight-forward answer.
