Performance Issues with nvdsosd Plugin and nsys Profile (deepstream6.2)
• Hardware Platform (Jetson / GPU) : gpu
• DeepStream Version : 6.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) :515.48.07
• Issue Type( questions, new requirements, bugs) :questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing):
set different font size of text
I use the nvdsosd plugin to put multiple lines of text on an image with different font sizes, and it takes almost 10 ms per frame. However, when I set all these lines of text to the same font size, it just takes 0.6 ms, which seems to be more normal. Why does using different font sizes take so long?
I also used nsys profile to obtain the profile information, as shown in the following figure: We can see that there are a large number of blank spaces during the execution of nvdsosd. What is the GPU doing during these blank periods? Is it waiting for locks or something else? How can I modify the nsys profile instruction so that I can see the APIs executed during these blank periods?
Can you tell us whether it takes around 10 ms for every frame or just the first frame?
Every frame.
As long as the font size changes, it will take a long time.
Can you post the complete nsight file?
Can you provide the test app which will change font size?
