Performance of gst-dsexample deepstream
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version Deepstream 6.0
• JetPack Version (valid for Jetson only) Jetpack 4.6 rev3
• TensorRT Version 8.0.1
I am using blur_objects of gst-dsexample for pre-processing and I observe a latency. Is it because in gst-dsexample opencv operations are off-loaded to CPU?
I have seen similar issue: Performane of Deepstrem gst-dsexample plugin
How to implement pre-processing in gst-dsexample on GPU seamlessly?
You may consider to implement the blur algorithm with CUDA to accelerate by Nvidia GPU. About CUDA | NVIDIA Developer
Sorry for the late reply but of late I am concerned of RTSP stream of deepstream app to VLC. By using nvvoverlaysink with sync=0 I face very little latency to make the app work but when using RTSP over a VLC media player, I see a lot of latency while visualizing the output of deepstream app. How can I make such visualization hardware accelerated?
RTSP is network transferring. It can not be accelerated by any other HW but your network adapter.
Thank you for the resolution
