Dear,
1.Do you have official standard test results for speccpu for Orin CPUs? If not, can your company help test and optimize the test configuration, and provide a benchmark result.
2.For Orin’s built-in EMMC hard drive, we have found through actual testing that the sequential read and write bandwidth is 40% -50% lower than the spec of the hard drive. Can your company help test and analyze the reasons for the deviation in the results
B&R.
No, we don’t have the test report. You may goodle it to know general testing method on CPU.
Please open a new topic with the system setup and test result, then we can try to investigate that problem.
Got it with thanks.
