Hi all,
I have some code implemented in C++ based on intel mkl, the major calculation in the code is a big matrices multiplication. One matrix (A) is of 17000x17000 which will be multiplied with another matrix (B) of 17000x200. Both A and B are complex matrix of double type. Matrix A is a band matrix with each (main and off-) diagonal is a constant number, just like
A_{n, n} = c0
A_{n, n+1} = c1
A_{n, n+2} = c2
I used the following code (matrix and complex number are wrapped by thrust and cusp::complex) to do the multiplication
thrust::device_vector A(17000*17000), B(17000*200);
int m = 17000, n=200, k=17000;
cusp::complex<double> alphac = cusp::complex<double>(1, 0);
cusp::complex<double> betac = cusp::complex<double>(0, 0);
status = cublasZgemm(handle, CUBLAS_OP_N, CUBLAS_OP_N, // C(m*n) = A(m*k) * B(k*n)
m, n, k,
&alphac,
thrust::raw_pointer_cast(&A[0]),
m,
thrust::raw_pointer_cast(&B[0]),
k,
&betac,
m);
I will say this code is faster than the mkl implementation. But I have to repeat the same operation for about 20000 times, so it still to quite long before it’s done. Since I don’t have any experience of CUDA programming before, I just want to ask if this is the right way to implement the matrix multiplication? Since the matrix of A is banded matrix, is that any special thing or function I can use to boost the efficiency? Thanks.
I point out just two possibilities that come to my mind:
cuBLAS has routines for matrix-vector multiplications for banded matrices; drawback: in your case, you should run them in a for loop to account for all the needed possibilities;
cuBLAS has batched operations for concurrent multiplications between small-sized matrices; you should segment the original matrix-matrix multiplication in several small-sized multiplications; drawback: you should again use for loops;
Be aware I have never tried those two possibilities before.
Thanks for the suggestion. I am thinking the second suggestion. I am wondering if you are saying something like stream or not. I used thrust for some while and don’t know much about CUDA programming. I am reading the CUDA doc this day and I saw many introduction on matrix multiplication with CUDA kernel instead of CUBLAS library. So should CUBLAS be faster? It is not many example online to introduce stream for matrix multiplication, I am still looking for example.
CUBLAS follows the reference BLAS implementation which does not define a function for multiplying a banded matrix by a general matrix. LAPACK does not seem to provide that functionality either, best I can tell. How sparse is the band matrix in question, i.e. how many sub- and superdiagonals does it have? Is it tridiagonal?
As long as you are implementing the desired operation via ZGEMM, you would definitely want to continue using CUBLAS’s version of it. The reason you can find many introductions to CUDA programming that use self-written matrix multiplies as an example is because it is a self-contained and easy to understand task that lends itself well to demonstrating some fundamental CUDA programming techniques.
But creating high-performance matrix multiplies like those provided by CUBLAS is a matter for experts (on any platform).
If the bandwidth is low (<20), I’d recommend using cusparse for the best possible implementation (ignoring of course a custom kernel implementation). For example, a tridiagonal matrix multiply 10^7 * 10^7 10^7 * 32 takes me roughly 0.05s
In your case it’s a toeplitz matrix, which can obviously further simplify calculations
ans = c0 * (D0V) + c1 * (D1 * V) + c2 * (D2 * V) whereby D0…Dn are permutation matrices. Using a custom kernel you could use that simplification to only require reads of a (bandwidth1) c vector and the right hand side matrix, and since banded*general is memory bound in most cases, the absolute best runtime you could get is
~= 1700020082 / (280102410241024) sec ~= 0.1ms. I believe it should be fairly easy to get to 10% of this peak, which is 1ms/calculation.
The batched version of cuBLAS use indeed streams, as long as I know. cusparse is indeed worth trying as pointed out by sBc-Random, I forgot to mention.
I second sBc-Random’s suggestion to look into using CUSPARSE, that is the reason I inquired about details with regard to the exact shape / properties of the band matrix.
Thanks all. The code was not generated by myself but I read the code carefully, I figure out that the banded matrix is not sparse. Almost all entries are non-zero, maybe it is not a good word to call it band matrix. It is nxn matirx with (n-2)x(n-2) diagonals with each diagonal a constant number.
That’s a very specialised kind of matmul - you are unlikely to find an optimized solution to that. Keeping in mind you don’t need to store the constant for each diag over and over again, but rather need to store a 2*(n-2) - 1 vector of constants. Once you have done this, you could code a very efficient matmul which would get some 10-20* speedup of gemm, I imagine :)
Matrix multiplication by a Toeplitz matrix and a dense matrix is equivalent to a cyclic convolution, which can be calculated by a standard FFT, see for example
Hi sBC-Random, I get the idea of using permutation matrices but I think it will take me some time to understand the math behind. I just wonder the reason why this will enhance the performance since we now have+1 matrices (permutation) and need n+1 multiplication, shall it be slower. Sorry if I misunderstanding some of your information.
BTW, you also mention the toeplitz matrices and FFT, I wonder if this is different scheme than the permutation one or it basically the same thing. I didn’t use FFT before and wonder if this will much faster than the cublas basic matrix multiplication. Again, I believe it will take me some times to learn all those methods.
I might not clarify my reply. What I am asking is if we have a nxn toeplitz matrix (A) which multiplies with a nxk matrix (B). As your suggestion, I can store a vector of (2xn+1) elements with each elements represent the constant diagonal element. So AxB can basically be implemented as 2n+1 vector-matrix multiplication. So will all those 2n+1 vector-matrix multiplication be faster than one matrix-matrix multiplication?
I’m suggesting something different from what sBc-Random is suggesting. Once you have understood the maths behind, interpreting the matrix multiplication between a Toeplitz matrix and a dense one as a convolution and implementing it by FFTs will be as easy as calling a routine of the cuFFT library, if I correctly understand your problem.
Be warned that I’m not claiming that this solution is either simpler or more effective than that suggested by sBc-Random. I’m just saying to think about :-)
Kilong,
Your best approach would be to use JFSebastian’s suggestion. Writing your own kernel WOULD produce better results, if you had infinite time to work on it, but I suspect cuFFT will come very, very close with not too much trouble.
It’s not the easiest problem to write your own kernel for. :)
I agree with that. I am still learning the idea of CUDA programming but honestly, I still don’t understand much about kernel because the CUDA programming is pretty much different from ‘traditional programming skill’ I learnt before :)
