Lets say i would do something like this inside my kernel
int *ptr = &global[tid];
ptr[0] = 23;
ptr[1] = 0;
instead of just
global[tid] = 23;
global[tid+1] = 0
My question is :
Would the int *ptr = &global[tid] considered to be an memory read or is it possible for the compiler optimize the two code parts be the same?
If you aren’t sure if the compiler is doing what you want then it’s best to either inspect the output directly or write a test for at least partial confirmation.
