Performance question or bug in a program?
Can someone explain peaks in attached chart.png, that i get if i run program with some multiple of 16 for threads?
As i understand adding one thread to existing 64 threads, should bring a lot of slowdown (as it is shown in the chart - for about the factor of 2), but if i would use 55, 63 threads or soo, slowdown shouldnt be soo obvious … or is that indication of some bug in my program :mellow: ?
[attachment=6721:attachment]
Regards
Blaz
This is most likely due to memory coalescing when you run a multiple of 16 threads. See the programming guide for the memory coalescing rules: coalesced accesses can be orders of magnitude faster than uncoalasced (70 GiB/s vs 3 GiB/s).
Also note that the warp size is 32, so you should always run blocks sized with a multiple of 32 threads.
in fact, for future-proof code, you should run block sizes with a multiple of the warp size you determine from
 cudaGetDeviceProperties(&deviceProp, chosenDevice);
instead of hard-coded 32’s :)
Please check the deviceQuery SDK example for details.
Yes, that might be the cause.
Thanks to both for help. :smile:
Regards,
Blaz
