Performance regression upgrading GStreamer application from JetPack 5.1.3 to 6.2 (latency and high CPU usage)
I am encountering a significant performance regression when migrating a GStreamer-based application from JetPack 5.1.3 to JetPack 6.2 on NVIDIA Jetson hardware, and I am seeking guidance on what has changed in JetPack 6.x or how this pipeline should be adapted.
The application:
  • Ingests two 1920×1080 camera streams via v4l2src
  • Stitches them into a 3840×1080 panoramic space
  • Displays only one screen-width (1920×1080) at a time
  • Allows interactive panning by dynamically updating xpos on compositor sink pads
  • Performs reliably with low latency and modest CPU usage on JetPack 5.1.3
The panning behavior is implemented entirely by updating compositor sink pad properties (xpos) at runtime.
Observed Behavior
JetPack 5.1.3
  • Very low end-to-end latency
  • CPU usage remains low and stable
  • Smooth, responsive panning
  • Reliable long-term operation
JetPack 6.2
  • Noticeable and increasing latency
  • Significantly higher CPU utilization
  • System appears stressed despite identical application logic
  • Overall responsiveness is much worse
The application code and camera configuration are unchanged between versions. CPU usage differences were observed using standard system monitoring tools while running identical workloads.
#include <gst/gst.h>
#include <unistd.h>
#include <termios.h>
#include <fcntl.h>
#include <stdio.h>
static int pan_offset = 0;              // 0 .. cam_width
static const int cam_width = 1920;
static const int cam_height = 1080;
// non-blocking keyboard
int kbhit() {
    struct termios oldt, newt;
    int ch;
    int oldf;
    tcgetattr(STDIN_FILENO, &oldt);
    newt = oldt;
    newt.c_lflag &= ~(ICANON | ECHO);
    tcsetattr(STDIN_FILENO, TCSANOW, &newt);
    oldf = fcntl(STDIN_FILENO, F_GETFL, 0);
    fcntl(STDIN_FILENO, F_SETFL, oldf | O_NONBLOCK);
    ch = getchar();
    tcsetattr(STDIN_FILENO, TCSANOW, &oldt);
    fcntl(STDIN_FILENO, F_SETFL, oldf);
    if (ch != EOF) {
        ungetc(ch, stdin);
        return 1;
    return 0;
int getch() {
    int ch;
    newt = oldt;
    ch = getchar();
    return ch;
static gboolean animate(gpointer data) {
    GstElement *compositor = GST_ELEMENT(data);
    GstPad *pad1 = gst_element_get_static_pad(compositor, "sink_0");
    GstPad *pad2 = gst_element_get_static_pad(compositor, "sink_1");
    if (!pad1 || !pad2) return TRUE;
    // keyboard input
    if (kbhit()) {
        int c = getch();
        if (c == 'a' || c == 'A') pan_offset -= 40;
        if (c == 'd' || c == 'D') pan_offset += 40;
        if (c == 27 && getch() == '[') {
            switch (getch()) {
                case 'D': pan_offset -= 40; break;
                case 'C': pan_offset += 40; break;
    if (pan_offset < 0) pan_offset = 0;
    if (pan_offset > cam_width) pan_offset = cam_width;
      True panoramic pan:
      cam1 moves left
      cam2 follows it without overlap
    g_object_set(pad1,
                 "xpos", -pan_offset,
                 "ypos", 0,
                 "width", cam_width,
                 "height", cam_height,
                 NULL);
    g_object_set(pad2,
                 "xpos", cam_width - pan_offset,
                 "ypos", 0,
                 "width", cam_width,
                 NULL);
    gst_object_unref(pad1);
    gst_object_unref(pad2);
    return TRUE;
int main(int argc, char *argv[]) {
    gst_init(&argc, &argv);
    GstElement *pipeline = gst_pipeline_new("pan-pipeline");
    GstElement *src1 = gst_element_factory_make("v4l2src", "cam1");
    GstElement *src2 = gst_element_factory_make("v4l2src", "cam2");
    GstElement *conv1 = gst_element_factory_make("videoconvert", NULL);
    GstElement *conv2 = gst_element_factory_make("videoconvert", NULL);
    GstElement *comp  = gst_element_factory_make("compositor", "comp");
    GstElement *capsf = gst_element_factory_make("capsfilter", NULL);
    GstElement *conv3 = gst_element_factory_make("videoconvert", NULL);
    GstElement *sink  = gst_element_factory_make("autovideosink", NULL);
    if (!pipeline || !src1 || !src2 || !conv1 || !conv2 || !comp || !capsf || !conv3 || !sink) {
        g_printerr("Failed to create elements\n");
        return -1;
    g_object_set(src1, "device", "/dev/video2", NULL);
    g_object_set(src2, "device", "/dev/video0", NULL);
    GstCaps *outcaps = gst_caps_new_simple("video/x-raw",
                                           "width", G_TYPE_INT, cam_width,
                                           "height", G_TYPE_INT, cam_height,
                                           NULL);
    g_object_set(capsf, "caps", outcaps, NULL);
    gst_caps_unref(outcaps);
    gst_bin_add_many(GST_BIN(pipeline),
                     src1, conv1,
                     src2, conv2,
                     comp, capsf, conv3, sink, NULL);
    gst_element_link(src1, conv1);
    gst_element_link(src2, conv2);
    gst_element_link_many(comp, capsf, conv3, sink, NULL);
    GstPad *sinkpad1 = gst_element_get_request_pad(comp, "sink_%u");
    GstPad *sinkpad2 = gst_element_get_request_pad(comp, "sink_%u");
    GstPad *srcpad1 = gst_element_get_static_pad(conv1, "src");
    GstPad *srcpad2 = gst_element_get_static_pad(conv2, "src");
    gst_pad_link(srcpad1, sinkpad1);
    gst_pad_link(srcpad2, sinkpad2);
    gst_object_unref(srcpad1);
    gst_object_unref(srcpad2);
    // initial state: only left cam visible
    g_object_set(sinkpad1,
                 "xpos", 0,
                 "ypos", 0,
                 "width", cam_width,
                 NULL);
    g_object_set(sinkpad2,
                 "xpos", cam_width,
                 "ypos", 0,
                 "width", cam_width,
                 NULL);
    gst_element_set_state(pipeline, GST_STATE_PLAYING);
    GMainLoop *loop = g_main_loop_new(NULL, FALSE);
    g_timeout_add(30, animate, comp);
    printf("Controls:\n");
    printf("  A / Left Arrow  = Pan Left\n");
    printf("  D / Right Arrow = Pan Right\n");
    g_main_loop_run(loop);
    gst_element_set_state(pipeline, GST_STATE_NULL);
    gst_object_unref(pipeline);
    return 0;
To isolate the issue, I constructed the following gst-launch pipeline, which achieves the same functional behavior using NVIDIA-accelerated elements:
gst-launch-1.0 \
  v4l2src device=/dev/video2 ! \
    image/jpeg,width=1920,height=1080,framerate=30/1 ! \
    nvv4l2decoder mjpeg=1 ! \
    nvvidconv ! video/x-raw(memory:NVMM) ! comp.sink_0 \
  v4l2src device=/dev/video0 ! \
    nvvidconv ! video/x-raw(memory:NVMM) ! comp.sink_1 \
  nvcompositor name=comp \
    sink_0::xpos=0 sink_0::ypos=0 \
    sink_1::xpos=1920 sink_1::ypos=0 \
    ! video/x-raw(memory:NVMM),width=1920,height=1080 \
    ! nvvidconv ! nveglglessink sync=false
Result
  • Low latency
  • Minimal CPU usage
  • Stable behavior on JetPack 6.2
This confirms that hardware decode, NVMM zero-copy, and GPU-based compositing are functioning correctly on JetPack 6.2 when using gst-launch.
I have attempted to convert the C++ application to use the NVIDIA-accelerated equivalents (nvv4l2decoder, nvvidconv, nvcompositor, nveglglessink) to match the working gst-launch pipeline.
However, I have encountered difficulties preserving the interactive panning behavior:
  • Dynamic updates to xpos on nvcompositor sink pads do not behave as expected
  • In some cases, panning stops working or triggers renegotiation
  • Achieving the same low-latency, GPU-only behavior in C++ has proven difficult despite matching elements and caps
This contrasts with the gst-launch pipeline, where nvcompositor performs well and remains GPU-accelerated.
  1. Have there been architectural or behavioral changes to compositor in JetPack 6.x that could explain the latency and CPU increase?
  2. Is compositor now strictly CPU-based, and if so, is its use discouraged in JetPack 6.x?
  3. Is nvcompositor the recommended replacement for low-latency interactive panning, and are there specific constraints when dynamically updating xpos?
  4. Are there required caps, memory types (NVMM), or properties that must be explicitly enforced in C++ to avoid renegotiation or CPU fallback?
  5. Is dynamically changing xpos on compositor sink pads still considered a supported low-latency approach in JetPack 6, or is there a newer recommended method?
    My goal is to restore JetPack 5.1.3–level latency and CPU efficiency on JetPack 6.2 while maintaining interactive panning behavior in a C++ GStreamer application.
Any guidance, best practices, or references to JetPack 6 migration notes would be greatly appreciated.
Thank you for your time and support.
Best regards,
Gabriel
On Jetpack 6.2, please run the script to fix VIC and CPU at maximum clock:
Big delay for first GStreamer nvvidconv when using GPU - #9 by DaneLLL
And please refer to this:
Making sure you're not a bot!
[gstreamer/MMAPI] cannot run hardware encoder in maximum performance mode
And apply the same to nvdec to enable hardware decoder at maximum clock.
Hi, DaneLLL,
Thanks again for your previous guidance — following your suggestion, we were able to get a live dual-camera feed running using hardware decoding, nvcompositor, and nveglglessink without any CPU memory copies. Both 1920×1080 streams now appear side-by-side on a 3840×1080 compositor canvas, and we can verify that the pipeline works end-to-end.
Here’s where we are currently hung up:
Dynamic xpos updates: We want to implement real-time panning of the output window by adjusting the xpos property of each compositor pad. When attempting this in C++ using g_object_set(comp_pad, "xpos", value, NULL), the pipeline crashes with NvBufSurfTransformMultiInputBufComposite failed.
Our goal is a hardware-accelerated, zero-copy pan over a 3840×1080 canvas with a 1920×1080 view window, controlled in real time via user input.
Could you advise:
  • The correct approach for dynamic compositor pad repositioning at runtime without causing fatal crashes?
  • Any safe constraints on xpos updates for panning within NVMM buffers?
  • Whether there’s a recommended JetPack 6.2-native element for runtime pan/crop that avoids CPU copies entirely?
Thank you for your time and guidance — any insights here would be greatly appreciated.
Best regards,
Gabriel
By desfault dynamic xpos is not supported in nvcompositor. The plugin is open source. and you can check the source code and implement the function. The source code is in
Jetson Linux Release 36.4.4 | NVIDIA Developer
Driver Package (BSP) Sources
We would suggest use nv3dsink on Jetpack 6.
BTW, which Jetson platform do you use? This topic is in Xavier NX category but we support Xavier series up to Jetpack 5. You cannot flash it to Jetpack 6. A bit confusing.
Thanks for the help I was able to modify the source code, sorry for the confusion I am on a Jetson Orin NX. My apologies.
