Perftest failure
Hi all,
I tried to use perftest to measure the lat and bw of two nodes with mlx5_0 and mlx5_1 but always got following error. Is there anyone can show how to correctly run perftest? Thank you.
./ib_send_bw -R -d mlx5_1
 WARNING: BW peak won't be measured in this run.
 Port number 1 state is Down
 Couldn't set the link layer
 Couldn't get context for the device
Could you paste ibstat output? It seems like your port is down.
Thanks,
Suo
CA 'mlx5_0'
        CA type: MT4125
        Number of ports: 1
        Firmware version: 22.37.1014
        Hardware version: 0
        Node GUID: 0x946dae0300ae6cec
        System image GUID: 0x946dae0300ae6cec
        Port 1:
                State: Down
                Physical state: Disabled
                Rate: 40
                Base lid: 0
                LMC: 0
                SM lid: 0
                Capability mask: 0x00010000
                Port GUID: 0x966daefffeae6cec
                Link layer: Ethernet
CA 'mlx5_1'
        CA type: MT4125
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x946dae0300ae6ced
        Port 1:
                State: Down
                Rate: 40
                Base lid: 0
                LMC: 0
                SM lid: 0
                Port GUID: 0x966daefffeae6ced
So you can see, the port status is down, if you want run perftest, you must make the port to active.
            Link layer: InfiniBand
CA ‘mlx5_2’
CA type: MT4121
Number of ports: 1
Firmware version: 16.35.3006
Hardware version: 0
Node GUID: 0x1c34da03006582bd
System image GUID: 0x1c34da03006582bc
Port 1:
State: Active
Physical state: LinkUp
Rate: 100
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0x1e34dafffe6582bd
Thanks,
Suo
how should I activate it?
I tried
ibportstate 0 2 enable
ibwarn: [610173] get_abi_version: can't read ABI version from /sys/class/infiniband_mad/abi_version (No such file or directory): is ib_umad module loaded?
ibwarn: [610173] mad_rpc_open_port: can't open UMAD port ((null):0)
ibportstate: iberror: failed: Failed to open '(null)' port '0'
and
ibportstate -G 0x966daefffeae6cec 0
ibwarn: [709172] get_abi_version: can't read ABI version from /sys/class/infiniband_mad/abi_version (No such file or directory): is ib_umad module loaded?
ibwarn: [709172] mad_rpc_open_port: can't open UMAD port ((null):0)
Are you use Ib or ethernet?
