Periodic ~0.9 s display stall every ~5 min at 4K 120 Hz: eglSwapBuffers blocks in poll(/dev/nvidia0), all GL clients affected
System
  • GPU: GeForce RTX 4070 Ti SUPER (01:00.0), VBIOS 95.03.45.80.6B
  • Driver: 615.78.08 (open kernel module, GSP). Also reproduced identically on 595.104.02 (open) and 580.178.04 (closed kernel module, NVreg_EnableGpuFirmware=0, GSP off)
  • Kernel 7.1.0, Gentoo, X.Org 1.21.1.25, XFCE/xfwm4 with compositing disabled, no Wayland
  • Monitor: ASUS ROG Swift OLED PG32UCDP, firmware MCM106 (latest), DisplayPort, 3840x2160 @ 120 Hz, VRR capable
  • CPU i7-6700, Gigabyte Z170M-D3H
  • xorg.conf: Driver nvidia, metamodes “3840x2160_120 +0+0”, ForceCompositionPipeline/ForceFullCompositionPipeline Off, ConnectToAcpid False, Composite extension disabled
  • modprobe: nvidia-drm modeset=1 fbdev=0, NVreg_DynamicPowerManagement=0, RegistryDwords PowerMizerEnable=0x1;PerfLevelSrc=0x2222;PowerMizerDefault=0x3;PowerMizerDefaultAC=0x3
Symptom
Any video playing on screen (Chrome/YouTube, mplayer -vo gl) freezes for about 1 s roughly every 5 minutes while audio continues. Every GL client on the GPU stalls at the same instant: an idle Chrome GPU process and an independent windowed mplayer -vo gl were caught stalling in the same second.
Measurement
  • chrome://tracing: a single NativeViewGLSurfaceEGL:RealSwapBuffers call on the Chrome GPU main thread blocks for ~1001 ms; nothing else in the trace is abnormal.
  • /proc sampling at 10 Hz (custom watcher): during the stall the thread is in poll(fd=/dev/nvidia0, events=0x3, timeout=1000 ms) inside eglSwapBuffers and returns after 780-930 ms, i.e. the awaited event is delivered late rather than the poll timing out.
  • The GPU interrupt (dedicated MSI, IRQ 147) keeps firing at the normal ~120-180/s through the stall. CPU, X server (1% CPU), and all other processes are idle at that second. No Xid, no NVRM or nvidia-modeset messages in dmesg, nothing in Xorg.0.log.
  • Cadence at 3840x2160@120: 300-312 s between stalls, e.g. 17:10:33, 17:15:17, 17:20:23, 17:25:27, 17:30:31 (2026-10-14) and 12:50:54, 12:56:17, 13:01:27, 13:06:11, 13:11:40 (2026-10-15, driver 580 closed, GSP off). At 3840x2160@60 the stall still occurs but only about once per 30 min.
  • 83 such stalls logged over 5 days; each one is 780-930 ms, never longer.
Ruled out by measured A/B tests (stall unchanged)
Change Result
Driver 615.78.08 / 615.71.09 (open, GSP) vs 595.104.02 (open, GSP) vs 580.178.04 (closed, NVreg_EnableGpuFirmware=0) identical
ForceCompositionPipeline On / ForceFullCompositionPipeline On identical
AllowFlipping=0, AllowVRR/AllowGSYNC=0, monitor VRR off identical
nvidia-smi -lgc clock floor, PowerMizer max identical
New VESA-certified DP80 cable identical
Monitor DSC off (4K120 without DSC) identical
3840x2160@60 rarer (~1 per 30 min), not gone
Software vs hardware video decode, codec, Chrome flags/profile identical (0 dropped frames from decode)
X screensaver timer (xset s off / 60 / 300), monitor OLED pixel-shift, Nextcloud client, CPU load, IRQ affinity identical
Reproduction
  1. X11 session at 3840x2160_120 on the DP-connected monitor, no compositor.
  2. Play any video in Chrome (or mplayer -vo gl) windowed or fullscreen.
  3. Sample the GPU-process main thread’s /proc/<pid>/task/<tid>/syscall at 10 Hz, or just watch: about every 5 minutes the picture freezes for ~0.9 s.
Attached
  • nvidia-bug-report.log.gz taken within a minute of a logged stall
  • Excerpt of the watcher log around that stall
nvidia-stall-watcher-excerpt.txt (2.4 KB)
nvidia-bug-report-sanitized.log.gz (461.1 KB)
